[mapserver-users] PHP MAPSCRIPT (fwd)
Daniel Morissette
morissette at dmsolutions.ca
Thu Oct 4 14:12:33 EDT 2001
> From: "CATHIGNOL, Frederic" <Frederic.CATHIGNOL at astrium-space.com>
> I have some difficulties to create new different kind of layers dynamically.
> The number of layer does not increase !
> Do you have a full example witch doesnot use a .MAP file for creating layers
Frederic,
Your layers were created properly and you should be able to use them,
it's just that the $map->numlayers member was not updated properly in
the PHP wrapper object.
I have fixed this in the CVS version. However, the copy of the code in
CVS today doesn't compile, hopefully this will be fixed in the next day
or two and then you can build a new executable from the latest CVS
source.
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
