[mapserver-users] Perl/Mapscript Summary
Tim Sutton
sutton_t at giug.net
Fri Oct 5 17:50:29 EDT 2001
Do I need to do something similar for compiling php_mapscript from cvs?
Thanks
Tim
On Fri, 5 Oct 2001, Paul Ramsey wrote:
> If you are having trouble with Perl/Mapscript (as I was) here is the
> summary of things you will need to know:
> - To build it from the CVS tree, you need to first copy the
> mapscript.i file into the perl directory. Then use the 'swig'
> program thusly: 'swig -shadow -perl5 mapscript.i'. Ignore the
> warnings. This will generate the mapscript_wrap.c file. Then do
> the usual perl compilation: perl Makfile.PL ; make ; make install
> - Note that you *cannot* use the 1.3.x recent development versions
> of SWIG to do this, or you will get funny results later on.
> Use the "stable" version, 'SWIG Version 1.1 (Build 883)'
> Follow the directions above and all will be sweetness and light.
