[mapserver-users] Running ./configure bails on me
Tyler Mitchell
TMitchell at lignum.com
Fri Oct 12 12:47:26 EDT 2001
Thanks for the question Stephen, as simple as it appeared, I did NOT have
it installed!
I guess, to date, I've been fortunate to only be using C code as far as I
can tell.
I installed the gcc-c++ rpm for Linux and it ./configured just fine so far.
Thanks again.
Tyler
"Stephen Lime"
<steve.lime at dnr.st To: <TMitchell at lignum.com>, <mapserver-users at lists.gis.umn.edu>
ate.mn.us> cc:
Fax to:
10/12/01 09:38 AM Subject: Re: [mapserver-users] Running ./configure bails on me
Do you have g++ installed?
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Tyler Mitchell" <TMitchell at lignum.com> 10/12/01 11:27AM >>>
Hi guys,
I've been compiling lots of programs without any problems lately, but once
I tried to run ./configure from the latest download of ms_3.4.tar - it
tells me the following and gives up on me :(
loading cache ./config.cache
checking for gcc... gcc
checking whether the C compiler (gcc ) works... yes
checking whether the C compiler (gcc ) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking for c++... no
checking for g++... no
checking whether the C++ compiler (gcc ) works... no
configure: error: installation or configuration problem: C++ compiler
cannot create executables.
I'm not that adept at Linux permissions, but am getting there. It wouldn't
be related to the permissions/ownership that came with the tarball would
it?
Tyler J. Mitchell
Coordinator - Geographic Information Systems
Lignum Ltd - 180 Hodgson Road
Williams Lake, B.C. Canada
V2G 3P6
Phone: 250-392-3371
Fax: 250-398-3977
Email: tmitchell at lignum.com
