[mapserver-users] postgis/mapserver - interface
gispmpf at zipmail.com.br
Sat Oct 13 15:14:31 EDT 2001
First , i want to thank you all for the patience on respond all my newbie
questions...
and here is another...
Can i create a layer in the mapfile which connect a postgis database where
point are declared. I want to draw this points in a polygon which is the
first layer show in the web browser.Something like this:
__________ ___________
' ' ___________ ' '
' ' '__________ '
' ' ___________ ' '
' ' '__________ '
' ' (postgis line) ' '
(shpfile) (result in the web browser)
Can i do it using only the mapfile?
Can i do it using the mapfile described below?
Can i use symbol 0 to draw this lines?
All this can work?
Thanks
Joao.
>You can use postgres without using a scripting language. I think
>Lowell was suggesting testing the map file using the scripting >language.
>Steve
>Stephen Lime
>Data & Applications Manager
>Minnesota DNR
>500 Lafayette Road
>St. Paul, MN 55155
>651-297-2937
>>> <gispmpf at zipmail.com.br> 10/11/01 03:14PM >>>
Ok , but what I'm asking is if i can do it only using mapserver and its
".map" file and a database with postgis.
I want to read the points of the line in the postgis table and create a
layer with it as in the mapfile and show this points.
Do I have to use a script language to do it?
Can a do it only using the mapfile?
> There should be syntax in the programming/scripting
> language your using to turn the Postgre "trace"
> function on. In perl the syntax is "$dbh->trace(2);"
> where $dbh is an already declared database
> handle/connection. The trace will in turn place
> information regarding your database connection (if
> there is one) in the web server log file. In apache on
> RedHat the log is usually "/var/log/httpd/error_log".
> Hope that helps.
> Lowell Filak
--- gispmpf at zipmail.com.br wrote:
> Hello,
> I have another questio about mapserver/postgis
> interface...
> i have adapted the following script for mapserver:
> LAYER
> CONNECTIONTYPE postgis
> NAME 'Roads'
> CONNECTION "user=postgres dbname=teste
> host=localhost"
> DATA "linha from teste"
> STATUS ON
> TYPE LINE
> FILTER "id = 1"
> CLASS
> EXPRESSION ([id]=1)
> COLOR 255 22 22
> SYMBOL 0
> SIZE 2
> END
> CLASS
> # All the rest are darker and only 1 pixel wide
> EXPRESSION ([id]>1)
> COLOR 205 92 82
> END
> END
> my intention is to draw the lines of this database
> in a web browser
> but i dont have any results with it
> How can i know if this script is realy conecting
> with the postgis database?
> and if it is ... how can i see what is wrong?
> Thanks
> João.
___________________________________________________________
http://www.zipmail.com.br O e-mail que vai aonde você está.
