[mapserver-users] Geographic query with postgis
jrom
jga at scot.cnes.fr
Tue Oct 16 04:36:20 EDT 2001
I'm using mapserver with postgis data.
It's working wonderfully! But i've a problem with more
complex geographic query. For example, i want to get
all the houses within a distance of 500 m from roads.
A sql query would be:
SELECT house.geo_value, road.geo_value
FROM house, road
WHERE Distance(house.geo_value, road.geo_value) < 500
It works in an sql console without problem.
So i try to do the same in the mapfile.
DATA "house.geo_value, road.geo_value FROM house, road"
FILTER "Distance(house.geo_value, road.geo_value) < 500"
This time it doesn't work and mapserver returns an error:
msPOSTGISLayerWhichShapes(): Query error. Error parsing
POSTGIS data variable. Must contain 'geometry_column FROM
table_name'.
It seems that you canno't access more than one table or column in the
DATA field of the mapfile.
Any clue for this problem?
Thanks in advance
jrom
