[mapserver-users] Installing PHP Mapscript
Assefa Yewondwossen
assefa at dmsolutions.ca
Mon Oct 22 11:04:22 EDT 2001
Hi There,
I think your problem is that you do not have the dll's related to
libwww. Here is an e-mail sent earlier that should hopefully solve your
problem :
I realized that I had in my compilation a link to the libwww libarary
(which is used for the WMS CLIENT in
mapserver). There is a need to have some dll's related to libwww for
this version to work properly. I have placed 2
zip files :
http://www2.dmsolutions.ca/mapserver/dl/php4.0.6_php_mapscript_35.zip :
with no libwww support.
http://www2.dmsolutions.ca/mapserver/dl/php4.0.6_php_mapscript_35_libwww.zip
: with libwww support
Please use the one without the libwww support and it should resolve the
problem.
Best Regards,
Brian Fischer wrote:
> Hi list,
> I am trying to install PHP4.0.6 and MapServer/MapScript 3.5 on a
> Microsoft IIS 5.0 Server.
> I was wondering if anyone has any insight to what may be wrong with my
> setup.I downloaded the mapscript zip file from
> http://www2.dmsolutions.ca/mapserver/dl/php4.0.6_php_mapscript_35_libwww.zip.I
> followed the install instructions and the How_tos and can not seem to
> see what is causing this error.I seem to have all of the names right.I
> also searched the archive and all of the messages about this subject
> point to incorrect version of mapscript with the version of php, but I
> seem to have that right.PHP seems to work fine, but it does not find
> the mapscript .dll.
> The .dll file is in c:\php\extensions\php_mapscript_35.dll
> My php.ini file looks like:
> ; Directory in which the loadable extensions (modules) reside.
> extension_dir = c:\php\extensions\
> The Php script looks like:
> <HTML>
> <BODY>
> <?php
> if (PHP_OS == "WINNT" || PHP_OS == "WIN32")
> dl("php_mapscript_35.dll");
> else
> dl("php_mapscript_35.so");
> phpinfo();
> </BODY>
> </HTML>
> And I get this error:
> Warning: Unable to load dynamic library
> 'c:\php\extensions\php_mapscript_35.dll' - The specified module could
> not be found. inc:\inetpub\wwwroot\projects\phpinfo_mapscript.php on
> line 8
> Here is the results page:
> http://www.houstoneng.com/projects/phpinfo_mapscript.php
> Any ideas?
> Thanks,
> Brian
> Brian Fischer
> Houston Engineering, Inc.
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056
Fax: (613) 565-0925
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20011022/8ad6932c/attachment.html
