[mapserver-users] Embeded scalebar object drawn under other layers
Armin Burger
armin.burger at territoriumonline.com
Mon Oct 22 12:12:39 EDT 2001
you could try it with
POSTLABELCACHE true
in the map file section for 'scalebar'. I know that at least line layers are
often drawn over the embedded scalebar if postlabelcache is not set to true.
Armin
> Hi,
> I used several nightly build of mapserver 3.5. I've a problem
> regarding the embeded scalebar which is drawn under others layers
> instead of being on the top of them. I've compiled mapserver
> under gd-1.8.4 with gif patch (from http://www.rhyme.com.au/gd).
> Any ideas?
> Regards
> jrom
