[mapserver-users] mapscript queryUsing Point question
Robert Chavez
rchavez at perseus.tufts.edu
Mon Oct 22 15:59:08 EDT 2001
Greetings,
I'm having some trouble workign with a point query in mapscript, I'm
using the 3.3.011 release.
I have the following Perl code and map file working, but I get no
results from a point query when there should definitely be some results.
First, here's the Perl code:
<snip>
sub shape_query {
my ($x, $y, @imgclick, $query_point, $query_buffer, $layer,
$results, $foo);
##Capture the user's click point
@imageclick = split (' ', $cgi->param('imgxy'));
print STDERR "The imageclick is: @imageclick\n";
$x = $imageclick[0];
$y = $imageclick[1];
##Setup the queryByPoint parameters
$query_point = new pointObj;
print STDERR "x: $x\n";
print STDERR "y: $y\n";
$query_point->{x} = $x;
$query_point->{y} = $y;
##Get the layer, perform the query
$layer = $map->getLayerByName('kwstreetVRnodes');
$layer->{status} = $mapscript::MS_ON;
print STDERR "About to start\n";
$results = $layer->queryUsingPoint($map, $query_point, MS_SINGLE,
-1);
print STDERR "Finished\n";
my $foo = $results->{numresults};
print STDERR "The number of results is: $foo\n";
##Put the results in some useable form
for (my $i=0; $i<$results->{numresults}; $i++) {
$data = $results->next();
print STDERR "the shape_query results are: $data\n";
$results->free();
return;
</snip>
And the map file:
<snip>
LAYER
NAME kwstreetVRnodes
TYPE POINT
STATUS DEFAULT
DATA kwstreetnodes
SYMBOLSCALE 5000
LABELMAXSCALE 1550
TOLERANCE 10
CLASS
SYMBOL 3
MAXSIZE 25
MINSIZE 3
SIZE 3
COLOR 204 0 0
TEXT ([STREET_NAM],[CAMERA_NAM])
LABEL
FORCE TRUE
COLOR 0 0 0
FONT arial
TYPE TRUETYPE
SIZE 3
MINSIZE 3
MAXSIZE 7
ANTIALIAS
POSITION CR
END
END
QUERY
TEMPLATE dummy
END
END
</snip>
Basically, for any click on a feature on a map, I get no results (I
copied an output sample from my error_log below). It's almost as if
mapscript isn't picking up the layer or the query in the layer, but I
can't figure out why. I was also thinking that my mapObj ($map) was the
problem, but it checks out OK (it's a global).
Any help would be greatly appreciated.
Rob
>From the error_log:
The imageclick is: 226 223
x: 226
y: 223
About to start
Finished
Can't call method "free" on unblessed reference at
/home/rchavez/www/web/cgi-bin/city-view.pl line 51.
[Mon Oct 22 15:45:56 2001] [error] [client 130.64.37.59] Premature end
of script headers: /home/rchavez/www/web/cgi-bin/city-view.pl
