[mapserver-users] [Fwd: ASP Template]
Brian Fischer
bfischer at mpls.houstoneng.com
Tue Oct 23 17:10:58 EDT 2001
Ualfrido Del Carlo Jr,
Answer to question 1.
I am pretty sure the reason why your .asp page is not working is because
mapserv (the CGI program) does not send the results back to the server.
It sends the results straight to the client, so your asp code never gets
processed by the server. If I am wrong please speak up. This same
question came up a few months ago on the listserv, but I could not seem
to find the original posting and response. I do not know a way around,
besides using MapScript/PHP.
I have gotten around this by using an intermediate page to send to the
client that contains a link to the ASP page. Take a look at this web
page I am working on, it uses ASP to interact with the database. Query
a permit and you will see the intermediate page that contains the link
to the ASP page. http://www.houstoneng.com/projects/sandhill/
This is one of the reasons I am trying to get away from using ASP and
trying to learn MapScript/PHP.
Hope this helps,
Brian
-----Original Message-----
From: Jamie Smedsmo [mailto:jsmedsmo at gis.umn.edu]
Sent: Tuesday, October 23, 2001 1:45 PM
To: mapserver-users at lists.gis.umn.edu
Cc: Ualfrido Del Carlo Jr
Subject: [mapserver-users] [Fwd: ASP Template]
-------- Original Message --------
Subject: ASP Template
Date: Tue, 23 Oct 2001 16:32:55 -0200
From: Ualfrido Del Carlo Jr <ualfrido at engecorps.com>
To: "'mdp at lists.gis.umn.edu'" <mdp at lists>
Question 1:
I´m trying to open a ASP file at the query mode with the template comand
in the map file, but it doesn´t work. Is there a limitation on Mapserv
with ASP? The asp alone work fine, but not when I call it by the query
mode. Can anyboby help me?
Question 2:
I need to select one City from a ComboBox or a TextBox and then show the
polygon that matchs the name and center at the map. I have trying a
couple of months but still without results.
I´m using Mapserv 3.5.
Thanks,
