[mapserver-users] problem with Portuguese idiom
tepán Kafka 2
stepan.kafka at centrum.cz
Thu Oct 25 10:33:45 EDT 2001
I had have the same problem with punctuation. The quickest solution is:
- using truetype fonts,
- using UNICODE characters for labeling map (I use extra column with UNICODE
coding for labeling in the attribute table).
Stepan Kafka
> -----Pùvodní zpráva-----
> Od: owner-mapserver-users at lists.gis.umn.edu
> [mailto:owner-mapserver-users at lists.gis.umn.edu]za uivatele Eduardo
> Patto Kanegae
> Odesláno: 25. øíjna 2001 1:40
> Komu: mapserver-users at lists.gis.umn.edu
> Pøedmìt: Re: [mapserver-users] problem with Portuguese idiom
> default font....
> this is my map file
> NAME sp # prefixo das imagens temporarias geradas
> EXTENT -53.110 -25.310 -44.162 -19.785 # limites do shp
> SIZE 600 600 # dimensoes da imagem
> SHAPEPATH "D:\InetPub\websites\ekanegae\mapserver\shp" # caminho para os
> SHPs
> IMAGECOLOR 255 255 255
> TRANSPARENT OFF # gerar GIF transparente
> WEB
> HEADER "../demo_header.html"
> TEMPLATE "../demo.html"
> FOOTER "../demo_footer.html"
> MINSCALE 10
> MAXSCALE 1550000000
> IMAGEPATH "D:\Inetpub\wwwroot\ms_demo\tmp\"
> IMAGEURL "/ms_demo/tmp/"
> # LOG "demo.log"
> END
> QUERYMAP
> SIZE 200 200
> STATUS ON
> STYLE HILITE
> COLOR 255 0 0
> END
> LEGEND
> KEYSIZE 18 12
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 89
> END
> STATUS ON
> END
> LAYER # inicia um objeto Layer
> NAME "municipios" # nome do Layer
> DATA sp # nome do SHP sem extensao
> STATUS DEFAULT # se nenhum layer for invocado, este ja vem ativo como
> PADRAO
> TYPE POLYGON # tipo de layer(poligono,line,ponto...)
> CLASS # define uma classe para representar o layer
> COLOR 255 250 192 # cor do layer
> OUTLINECOLOR 0 0 0 # cor do contorno do layer
> END # finaliza definicao de classe
> END # finaliza definicao do layer
> LAYER # inicia layer
> NAME "municipios"
> TYPE ANNOTATION
> DATA sp
> STATUS ON
> LABELITEM "NMUN"
> CLASSITEM "NMUN"
> LABELMAXSCALE 5000000
> CLASS # inicia classe
> EXPRESSION /./
> COLOR -1 -1 -1
> LABEL
> COLOR 0 0 0
> SHADOWCOLOR 255 255 255
> SHADOWSIZE 0 0
> TYPE BITMAP
> SIZE TINY
> POSITION CC
> PARTIALS FALSE
> BUFFER 2
> END # finaliza label
> END # finaliza classe
> END # finaliza layer
> END # fim do map file
> ----- Original Message -----
> From: "Stephen Lime" <steve.lime at dnr.state.mn.us>
> To: <lists at ekanegae.com.br>; <mapserver-users at lists.gis.umn.edu>
> Sent: Wednesday, October 24, 2001 6:53 PM
> Subject: Re: [mapserver-users] problem with Portuguese idiom
> > What type of font are you using?
> > Stephen Lime
> > Data & Applications Manager
> > Minnesota DNR
> > 500 Lafayette Road
> > St. Paul, MN 55155
> > 651-297-2937
> > >>> "Eduardo Patto Kanegae" <lists at ekanegae.com.br> 10/23/01 04:50PM >>>
> > i'm trying to display as annotation layer , the names of cities of Sao
> Paulo state of Brasil
> > but when the name of city is something like "Sao Paulo" or "Ribeirao
> Preto" or "Paulínea"...
> > it only displays "SA PAULO" or "RIBEIR O PRETO" or "PAUL NEA"
> > does it has a way to contour this or is it better i change
> field values on
> the .DBF?
