[mapserver-users] Widely spaced Diagonal Fill
Stephen Lime
steve.lime at dnr.state.mn.us
Thu Oct 25 13:05:38 EDT 2001
Try:
SYMBOL
NAME 'crosshatch'
TYPE VECTOR
POINTS
0 0
1 1
END
END
then in your class
SYMBOL 'crosshatch'
SIZE 5 # or whatever
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Armin Burger <armin.burger at territoriumonline.com> 10/25/01 11:27 AM >>>
Chip,
in the CLASS section you can use the SIZE tag for the size
(height/width/spacing) of the symbol. That should do what you want. You can
also do a scale-dependend fill pattern with the tag SYMBOLSCALE in the LAYER
section, but that effects all symbols and labels for the layer.
BTW: If somebody succeeded in creating a diagonal fill with a more than
one-pixel-wide fill line it would be nice to submit the example.
Armin
> I'm having trouble figuring out how to do a simple diagonal hash.
> If I use the following definition, I do get a diagonal fill (sort of)...
> SYMBOL
> NAME 'hash'
> TYPE VECTOR
> POINTS
> 0 0
> 1 1
> END
> END
> However, it's more of a checkerboard in that every other pixel is filled
> (which is what I would expect based on the definition).
> How would I do a more widely spaced fill (i.e. 45 degree lines with say, 5
> pixels of space between lines)? The following definition looks the same as
> the first:
> SYMBOL
> NAME 'hash'
> TYPE VECTOR
> POINTS
> 0 0
> 5 5
> END
> END
> Thanks!
> Chip Hankley
Armin Burger
Territorium Online
Siemensstrasse/Via Siemens 19 - 39100 Bozen/Bolzano - Italia
