[mapserver-users] Subsitute for styled in 3.5 symbol file?
Bart van Heijningen
bart at atsence.nl
Fri Oct 26 05:12:55 EDT 2001
Steve,
I just do not succeed in getting my good old highway line back using the
symbol file in 3.4 instead of the styled option which was available in 3.3.
I know that you said you posted the solution already but I only found the
following:
SYMBOL
NAME 'dashed1'
TYPE ELLIPSE
POINTS 1 1 END
FILLED
STYLE 10 5 5 10 END # 10 pixels on, 5 off, 5 on, 10 off
END
Steve
But this does not tell me how to make a triple line (two thick reds on the
outside and one yellow in the middle we use for highways)
Any ideas?
Bart
-----Oorspronkelijk bericht-----
Van: owner-mapserver-users at lists.gis.umn.edu
[mailto:owner-mapserver-users at lists.gis.umn.edu]Namens Stephen Lime
Verzonden: woensdag 26 september 2001 19:22
Aan: bart at atsence.nl; mapserver-users at lists.gis.umn.edu
Onderwerp: Re: [mapserver-users] Subsitute for styled in 3.5 symbol
file?
I posted the solution to this in a previous thread (several months ago) so
please see that for code snippets and so on. Basically you need to use
overlayed symbols (i.e. a thin line over a thick line) to achieve that
effect.
The only difference between the approaches is that the center of a line
is no longer transparent.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Bart van Heijningen" <bart at atsence.nl> 09/26/01 09:18AM >>>
Hi all,
Now the styled option is no longer available in the symbol.sym from version
3.5 I have not succeeded in making an highway as was possible with the
STYLED option in the line.sym file.
Like:
Symbol
Type STYLED
SYLE
-1 1 8
0 0 0
1 1 8
END
END
Any suggestions will be highly appreciated.
Bart
