[mapserver-users] Problem with libproj librarie??
    Matt Carlson
    matt at aruke.com
    Fri Oct 26 04:01:45 PDT 2001
mapserver may be trying to find the module in /usr/bin but i think proj4
installs it to /usr/local/bin if your running linux.  if it's there just
copy it over to /usr/bin and you should be fine.
regards
matt
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Sent: Friday, October 26, 2001 6:25 PM
Subject: [mapserver-users] Problem with libproj librarie??
> Hello!
> When I try to run mapserv I get error:
> mapserv: error in loading shared libraries: libproj.so.0: cannot open
shared
> object file: No such file or directory
> I have proj-4.4.4 installed, mapserver 4.5, gd-1.2, linux = slackware 7.1
> Can anyone tell me where is the problem? :)
> Thanks
> __________-
> Janis Bokans
More information about the MapServer-users
