[mapserver-users] Problem with libproj librarie??
Stephen Lime
steve.lime at dnr.state.mn.us
Fri Oct 26 13:39:21 EDT 2001
That will work on some systems. On others you can set the envirionment
variable LD_LIBRARY_PATH to contain a semi-colon list of directories
that contain shared libs. Using apache you can use the SetEnv directive
to do this in httpd.conf.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Paul Ramsey <pramsey at refractions.net> 10/26/01 11:25AM >>>
A more elegant solution is to edit /etc/ld.so.conf and add
/usr/local/lib to the list of directories. Then run 'ldconfig' to bring
all the library information up to date. Things should then work. (For
some reason, distributions do not have /usr/local/lib in ld.so.conf by
default, even though the directory exists by default in their
distributions. Must be to keep the newbies down.).
Matt Carlson wrote:
> mapserver may be trying to find the module in /usr/bin but i think proj4
> installs it to /usr/local/bin if your running linux. if it's there just
> copy it over to /usr/bin and you should be fine.
> ----- Original Message -----
> From: "Janis Bokans" <Janis.Bokans at vzd.gov.lv>
> To: <mapserver-users at lists.gis.umn.edu>
> Sent: Friday, October 26, 2001 6:25 PM
> Subject: [mapserver-users] Problem with libproj librarie??
> > Hello!
> > When I try to run mapserv I get error:
> > mapserv: error in loading shared libraries: libproj.so.0: cannot open
> shared
> > object file: No such file or directory
> > I have proj-4.4.4 installed, mapserver 4.5, gd-1.2, linux = slackware 7.1
> > Can anyone tell me where is the problem? :)
> > Thanks
> > __________-
> > Janis Bokans
