[mapserver-users] getting min/max extents
klehr1 at tampabay.rr.com
Tue Oct 30 12:52:50 EST 2001
Also in the demo there's a perl script showextent.pl I believe works as
well. Attached here. You have to compiled the perl stuff. I modified two
lines in the script to so that you use is ./showextent.pl <SHAPEFILE>
----- Original Message -----
From: Daniel Morissette <morissette at dmsolutions.ca>
To: Jim Burnett <jimburnett at ntelos.net>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Tuesday, October 30, 2001 11:05 AM
Subject: Re: [mapserver-users] getting min/max extents
> > Jim Burnett wrote:
> > Is there a small application that can tell me the min and max extents
> > for a shape file?
> If you have OGR/GDAL installed on your system then the OGRINFO program
> can return you the extents of a layer. See the OGRINFO examples at
> http://mapserver.gis.umn.edu/doc/ogr-howto.html#ogrinfo
> Also, a getExtent() method has been added to the shapeFileObj class in
> MapScript version 3.5 (Perl or PHP)... so that's another option.
> Daniel Morissette morissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
> Don't put for tomorrow what you can do today, because if
> you enjoy it today you can do it again tomorrow.
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20011030/dcf13218/showextent.obj
