[mapserver-users] Projection Problem
Frederik Ramm
mapserver at mail.remote.org
Sat Sep 1 07:10:35 EDT 2001
I'm using Map Server v4.3 with PROJ support compiled in. I have a
few shape files with European cities, rivers, and borders, downloaded
from ESRI. I'm using the shp2img utility for testing.
The data is in lat/long format. When not using a specific projection
(i.e. no PROJECTION sections in my map file), I have to use
EXTENT 5 47 17 58
to get a decent view of Germany & surrounding countries. There's a
layer called "citynames", defined as follows (more or less
copied from the demo application), which displays the city names just
about right:
LAYER
NAME citynames
TYPE ANNOTATION
DATA awscitie
STATUS ON
LABELITEM "city_name"
CLASSITEM "city_name"
LABELMAXSCALE 500000
CLASS
EXPRESSION /./
COLOR -1 -1 -1
LABEL
COLOR 0 0 0
SHADOWCOLOR 218 218 218
SHADOWSIZE 2 2
TYPE BITMAP
SIZE MEDIUM
POSITION CC
PARTIALS FALSE
BUFFER 2
END
END
END
After that success, I started using a projection. I inserted
PROJECTION
geographic
END
with all my layers, and
PROJECTION
"proj=tmerc"
"ellps=WGS84"
"lat_0=50"
END
in the MAP section and changed the extent to
EXTENT 380246.45 -321450.90 998622.55 1017529.68
Now the streams, coastlines, and borders get displayed fine in the new
projection, but the city labels do not show up any more.
If I single out the "citynames" layer for display, I get a map of
names only with the non-projection map file, and an empty image when I
try to use the projection.
Does anybody know why?
The sample images I generated, the map files I was using, and the
shapefiles are available here:
http://www.remote.org/frederik/tmp/msproj.tgz (roughly 1 MB).
Bye
Frederik
Frederik Ramm ## eMail frederik at remote.org ## N48°59.94 E008°24.36'
