[mapserver-users] Mapserv reporting error reading item added
to DBF file
Hockaday, John
JohnHockaday at auslig.gov.au
Mon Sep 3 18:32:38 EDT 2001
Andrea,
I'm not sure that this is the problem but this may help. The name of the
attribute column is case sensitive. ArcView often shows the name of the
attribute column in a different case to its actual case especially if you
are using a PC. Try finding out the actual case of the name of the
attribute column and using that in the mapserv map file.
John
> -----Original Message-----
> From: A. Giacomelli [SMTP:andreag at crs4.it]
> Sent: Tuesday, September 04, 2001 5:08 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [mapserver-users] Mapserv reporting error reading item added
> to DBF file
> Hi,
> I am running mapserver 3.4 on winnt.
> I have added (via ArcView) a column to one of my DBF files, to provide
> information necessary for classification of my features.
> Mapserv complains that it cannot find the item with the name
> corresponding to the new column....(the error comes from
> msFindRecords()).
> Any suggestions ?
> TIA and regards,
> Andrea Giacomelli
> Centre for Advanced Studies, Research and
> Development in Sardinia
> http://www.crs4.it/~andreag
