[mapserver-users] Itemquery in Mapscript(PHP)
Arthur, John
John.Arthur at voicestream.com
Tue Sep 4 10:01:22 EDT 2001
That was it! Thanks Laurent & Daniel. Now all I have to do is to get it to
zoom.
By the way,... does this happen with IIS also?
John Arthur
-----Original Message-----
From: Daniel Morissette [mailto:morissette at dmsolutions.ca]
Sent: Tuesday, September 04, 2001 9:19 AM
To: Arthur, John
Subject: Re: [mapserver-users] Itemquery in Mapscript(PHP)
"Arthur, John" wrote:
> Laurent,
> Thanks for your help. I must be doing something wrong, it didn't seem to
> work for me. I'm using 3.5
> When I run the search the first time, the map is returned, but nothing is
> highlighted or zoomed.
> When I run the search the second time, an error is returned:
> Warning: MapServer Error in msLoadMap(): ():(0) in c:\program
> files\apache group\apache\mapinfo\htdocs\drawquery.php on line 7
Did you install PHP under Apache as a CGI? On Windows PHP MapScript
won't work well with PHP installed as an Apache module.
If you downloaded the Win32 PHP4 distribution from http://php.net/ then
see the file "install.txt" that was included in the ZIP file and make
sure you follow the CGI installation for your web server.
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
