[mapserver-users] Itemquery in Mapscript(PHP)
Vladislav Kurnosov
vkurnosov at softech.ru
Tue Sep 4 10:41:16 EDT 2001
It seems as the mapserver code doesn't support multithreading
at all (I mean apartment-type threading, not free-threading).
Vladislav Kurnosov
Tuesday, September 04, 2001, 6:01:22 PM, you wrote:
> That was it! Thanks Laurent & Daniel. Now all I have to do is to get it to
> zoom.
> By the way,... does this happen with IIS also?
> John Arthur
> -----Original Message-----
> From: Daniel Morissette [mailto:morissette at dmsolutions.ca]
> Sent: Tuesday, September 04, 2001 9:19 AM
> To: Arthur, John
> Subject: Re: [mapserver-users] Itemquery in Mapscript(PHP)
> "Arthur, John" wrote:
>> Laurent,
>> Thanks for your help. I must be doing something wrong, it didn't seem to
>> work for me. I'm using 3.5
>> When I run the search the first time, the map is returned, but nothing is
>> highlighted or zoomed.
>> When I run the search the second time, an error is returned:
>> Warning: MapServer Error in msLoadMap(): ():(0) in c:\program
>> files\apache group\apache\mapinfo\htdocs\drawquery.php on line 7
> Did you install PHP under Apache as a CGI? On Windows PHP MapScript
> won't work well with PHP installed as an Apache module.
> If you downloaded the Win32 PHP4 distribution from http://php.net/ then
> see the file "install.txt" that was included in the ZIP file and make
> sure you follow the CGI installation for your web server.
