[mapserver-users] Center in lat/lon, radius in miles?
Bill Lubanovic
bill at madscheme.com
Fri Sep 7 12:17:19 EDT 2001
Although I've read the docs and the list archives, installed the demo,
and have built working applications, I'm stuck on something that sounds
simple.
I'm trying to plot a map with its center at a given lat/lon and a radius
of a given number of miles. The map would actually include features
within the bounding box of this circle, not clipped to the circle.
The data files (state/county/etc. boundaries) are good, and the
projection from lat/lon to lcc and other projections works in the
template file. But I'm not sure how to define the extent around the
center point, since the original lat/lon (DD) space doesn't equate to
miles. I'm approximating the bounding box by trial and error. Should I
use proj.4 to calculate the extents in miles from each lat/lon
counterpoint? Or is there a way in Mapserver to specify this directly?
Thanks,
Bill Lubanovic
Mad Scheme Limited
I wish I may/I wish I might/I wish I were/A trilobite
