[mapserver-users] point does not appear in mapscript (fwd)
teb
teb at mallit.fr.umn.edu
Tue Sep 11 09:24:18 EDT 2001
------------- Begin Forwarded Message -------------
To: <mapserver-info at lists.gis.umn.edu>
Subject: point does not appear in mapscript
Date: Tue, 11 Sep 2001 22:19:08 +1000
MIME-Version: 1.0
Content-Transfer-Encoding: 7bit
X-Priority: 3 (Normal)
X-MSMail-Priority: Normal
Importance: Normal
X-MimeOLE: Produced By Microsoft MimeOLE V5.50.4522.1200
I've been using MapServ in a very basic way for some time but have just
started working with mapscript. I have gotten a simple map to draw but what
I really want to do is to dynamically add points (based on a sql query,
though I think that is not relevant to this question).
My problem is in using the pointObj() method and specifically the class
parameter. I am a bit vague on this one but it seems to me that the symbol
and the colour used to draw the point is sourced from the class definition
in a layer called from the map file using the getLayerByName method. My
relevant layer statement in the map file is as follows:
########################################################################33
LAYER
NAME sw_sites
TYPE point
STATUS OFF
DATA locations
#DATA location_mi_point
labelitem "ID"
CLASS
SYMBOL 3
SIZE 7
NAME sw_sites
COLOR 254 0 0
LABEL
BACKGROUNDCOLOR 200 255 255
COLOR 30 94 94
SIZE SMALL
POSITION AUTO
WRAP " "
END
END
END
My mapscript code is as follows:
#! /usr/bin/perl
use CGI qw/:standard :html3 -no_debug/;
use mapscript;
$q = new CGI;
print $q->header();
$map = new mapObj("/www/hosted/streamwatch/cgi-bin/streamwatch.map") or
die('Unable to open mapfile.');
my $layer = $map->getLayerByName('regall');
$layer->{status} = $mapscript::MS_ON;
my $layer = $map->getLayerByName('ocean');
my $layer = $map->getLayerByName('rivall');
$point = new pointObj();
$point->{y} = $data->{'-33.7577'};
$point->{x} = $data->{'151.0188'};
$map->{extent}->{minx}= 150.9000;
$map->{extent}->{miny}= -33.6000;
$map->{extent}->{maxx}= 151.1000;
$map->{extent}->{maxy}= -33.8000;
$map->{height} = 300;
$map->{width} = 300;
my $img = $map->prepareImage();
#$layer->draw($map, $img);
$img = $map->draw() or die('Unable to draw map');
$layer = $map->getLayerByName('sw_sites');
$point->draw($map, $layer, $img, 0, "test point");
$map->drawLabelCache($img);
mapscript::msSaveImage($img, undef, $map->{interlace}, $map->{transparent});
The following link shows what result I get:
http://www.streamwatch.org.au/cgi-bin/testmapscript.pl
There should by rights be a small red triangle in somewhere near the center
of the map with the lable "test point".
I am clearly missing something fundamental. Can anyone help?
Regards
Steven Hayes
TND Computer Systems
Sydney NSW Australia
------------- End Forwarded Message -------------
