[mapserver-users] calculating x,y from lat,lon
Walt Lin
joemayfair at usa.net
Mon Sep 17 16:10:09 EDT 2001
Hi all,
I have mapserver generating a map image for me, and then I do my own calculation of x,y from lat,lon for certain points and overlay them. Sometimes they line up correctly, but most of the time, the x coordinate is very accurate but the y coordinate is off by a small margin. I would like to know the formula mapserver uses to calculate the pixel x,y from the lat,lon of a point, in the decimal degrees units. I have looked through the source but couldn't find it. The supposedly incorrect formula I have been using is:
x = (point_lon - left_lon) / (right_lon - left_lon) * image_width
y = (1 - (point_lat - lower_lat) / (upper_lat - lower_lat)) * image_height
(the pixel origin being in the upper left corner). Also, it is not feasible to simply give mapserver the point and have it do the work. I need to do the calculation outside of mapserver. I am guessing that it has something to do with the curvature of the earth and whether it is projecting points with a normal to the earth's surface or a normal to the plane of the image?
Thanks for any help,
Walt
