[mapserver-users] Mapserv 3.5 opaque tag
Daniel Morissette
morissette at dmsolutions.ca
Tue Sep 18 10:02:21 EDT 2001
Trem Stamp wrote:
> Just wondering if when a wms capabilities request is made using mapserv
> 3.5, the map file has the ability to define the opaque tag for a layer,
> and if so, how this is defined in the map file.
It was not supported until now, but I added it this morning (it's in
CVS). There is a new "wms_opaque" layer metadata that is used to
control the opaque layer attribute in the capabilites. This applies to
version 1.1.0 only and if "wms_opaque" is not defined then we assume
"opaque=0" as stated in the spec.
Now, about the other question that you had sent outside the list:
> Trem Stamp wrote:
> > I understand the builds for windows NT is done every week from CVS
> > automatically. I noticed that the last build was done on 31st August
> > and was hoping that this would have included the wms functionality.
> > It seemed that it only had the following.
> > MapServer version 3.5 (pre-alpha) OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> > OUTPUT=WBMP SUPPOR
> > TS=PROJ SUPPORTS=TTF INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=SHAPEFILE
> > Do you know when a build will be done which includes WMS and bug fixes
> > for tiled reprojection using raster images (which were fixed by you over
> > the last couple of weeks)?
I don't know about the builds at UMN, but there is one that's about 2
weeks old on our site and it includes WMS server support:
http://www2.dmsolutions.ca/mapserver/dl/php4.0.6_php_mapscript_35.zip
(I guess the filename does not suggest it, but it includes both the PHP
DLL and mapserv.exe)
We'll try to put a new one on our site later this week with the latest
fixes in it, and compiled with the latest PROJ and GDAL libs.
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
