[mapserver-users] strange behaviour of zoomscale() in phpmapscript
Daniel Morissette
morissette at dmsolutions.ca
Thu Sep 20 10:29:45 EDT 2001
Claude,
I think this is a bug, but even if it's not a bug then it's worth
looking into. I have filed it in bugzilla:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=46
Add your Email address to the CC: in the bug report if you want to be
informed when it's fixed.
And BTW, thanks for the clear description of the problem!
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
Claude Philipona wrote:
> Hello,
> We have observed a strange behaviour with the zoomscale method in PHPMpscript
> 3.5.
> If we set the zoomscale with a given scale, we get in return a scale that is not
> set equal to what we gave as parameter. There is always a shift, which appears,
> for a given width and height, to be a constant percentage of the scale. This
> appears anywhere on the map, even very far from the maximum mapextent.
> Is it a bug or a wrong use of the fonction? Actually, we need for our application
> to be able to zoom with a precise scale, to get one to one pixel representation
> of our raster image
> Here is an example of the problem
> we use:
> MapScript Version (Aug 29, 2001)
> MapServer version 3.5 (pre-alpha) OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS INPUT=EPPL7 INPUT=JPEG INPUT=OGR
> INPUT=GDAL INPUT=SHAPEFILE
> if we do:
> $Map->zoomscale($scale, $pixelpos,
> $width_pix, $height_pix,
> $georefext, $georefmaxext);
> with the following values (part of var_dump($Map->scale):
> $scale:
> int(28347)
> $pixelpos:
> ["x"]=> float(281) ["y"]=> float(277)
> $width:
> int(400)
> $height:
> int(400)
> $georefext:
> ["minx"]=> float(556933.36088877) ["miny"]=> float(111233.13134228) ["maxx"]=>
> float(562918.54274843) ["maxy"]=> float(117218.31320194)
> $georefmaxext:
> ["minx"]=> float(479231.75) ["miny"]=> float(65964.67) ["maxx"]=>
> float(847736.75) ["maxy"]=> float(320184.67)
> just after $Map->zoomscale() we get
> $new_scale: 28276.1325
> $new_extent (bbox): 559142.913985 111078.53760395 563132.98830536
> 115068.61192431
> we have a difference between what we asked and what we get of :
> 28347 - 28276.1325 = 70.8675 which is 0.25% (this factor is constant for 400x400
> map at any scale, but it chages with different scale).
> This behaviour doesn't depend on the initial scale prior to the call of
> zoomscale (in this example, the initial scale was 42414)
> Any idea on what is happening?
> Claude Philipona
