[mapserver-users] compile with TIFF
j1mmm
j1mmm at hotmail.com
Mon Sep 24 02:57:50 EDT 2001
I want to compile MapServer to read TIFF. I already have tiff-v3.5.5.zip But after compiled,
i got mapserv.exe, no TIFF effect, there is no different like it doesn't compile it. Do i have to configure anything else???
Thank for all help
j1mmm
these are my makefile.
====ms35gif_nightly.zip --> Makefile.vc=========
# makefile.vc - Main MapServer makefile for MSVC++
# This VC++ makefile will build MAPSERVER.LIB, MAPSERV.EXE, and the other
# MapServer command-line programs.
# To use the makefile:
# - Open a DOS prompt window
# - Run the VCVARS32.BAT script to initialize the VC++ environment variables
# - Start the build with: nmake /f makefile.vc
# $Id: Makefile.vc,v 1.12 2001/08/23 15:22:29 dan Exp $
#OPTFLAGS = /nologo /Zi /W3 /DDEBUG
BASE_CFLAGS = $(OPTFLAGS)
LDFLAGS = /NODEFAULTLIB:libcd
CC= cl
LINK= link
# If you want to ignore missing datafile errors uncomment the following
# line. This is especially useful with large tiled datasets that may not
# have complete data for each tile.
#IGNORE_MISSING_DATA=-DIGNORE_MISSING_DATA
# Apparently these aren't as commonplace as I'd hoped. Edit the
# following line to reflect the missing functions on your platform.
#STRINGS=-DNEED_STRCASECMP -DNEED_STRNCASECMP -DNEED_STRDUP
# Proj.4 distribution (cartographic projection routines). Not required for normal use. (EXPERIMENTAL)
PROJ_LIB=./proj/src/proj.lib
PROJ_INC=-I ./proj/src
PROJ=-DUSE_PROJ
#Use this flag to compile with WMS support
WMS=-DUSE_WMS
# GD distribution (graphics library GIF and/or PNG support). (REQUIRED)
# - Version 1.2 is included and writes LZW GIF (-DUSE_GD_GIF -DUSE_GD_SWAP_XY).
# - Versions 1.3 to 1.5 write non-LZW GIF (-DUSE_GD_GIF).
# - Versions 1.6 and greater write PNG (-DUSE_GD_PNG). Add -lpng -lz to GD_LIB line.
# - Versions 1.8 (or was it 1.7?) also supports JPEG and WBMP (-DUSE_GD_JPEG -DUSE_GD_WBMP)
# The following lines will compile GD 1.2:
#GDFONT_OBJ= gd-1.2/gdfontt.obj gd-1.2/gdfonts.obj gd-1.2/gdfontmb.obj \
# gd-1.2/gdfontl.obj gd-1.2/gdfontg.obj
#GD_INC= -I./gd-1.2
#GD_LIB= gd-1.2/gd.lib
#GD= -DUSE_GD_GIF -DUSE_GD_SWAP_XY
#MAKE_GD=gd
# A patched version of GD that supports GIF, JPEG, PNG and WBMP can be
# downloaded from http://www.rime.com.au/gd/.
# The following defns will include the patched GD 1.8.4 with TTF:
GDFONT_OBJ=
GD_INC= -I ./gd-1.8.4
GD_LIB= ./gd-1.8.4/gd.lib ./jpeg/libjpeg.lib ./libpng/projects/msvc/win32/libpng/dll/libpng.lib \
./zlib/release/zlib.lib ./freetype/lib/freetype200b8.lib
GD= -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_TTF \
-DUSE_GD_TTF -DGD_HAS_GDIMAGEGIFPTR
MAKE_GD=gd
# TIFF distribution (raster support for TIFF and GEOTIFF imagery).(RECOMMENDED)
TIFF_INC=-I./tiff/libtiff
TIFF_LIB=./tiff/libtiff/libtiff.lib
TIFF=-DUSE_TIFF
# JPEG distribution (raster support for grayscale JPEG images, INPUT ONLY).
JPEG_INC=-I./jpeg
JPEG_LIB=./jpeg/libjpeg.lib
JPEG=-DUSE_JPEG
# EPPL7 Support (this activates ERDAS as well) Included in the distribution. Probably the best raster alternative if
# you've got EPPL7 laying around. See http://www.lmic.state.mn.us/ for more information. (RECOMMENDED)
#EPPL=-DUSE_EPPL
#EPPL_OBJ=epplib.obj
# OGR Support OGC Simple Feature inspired interface for vector
# formats. See http://gdal.velocet.ca/projects/opengis/
GDAL_DIR= .\gdal
OGR=-DUSE_OGR
OGR_LIB = $(GDAL_DIR)/ogr/ogrsf_frmts/ogrsf_frmts.lib $(GDAL_DIR)/ogr/ogrsf_frmts/ogrsf_frmts_sup.lib $(GDAL_DIR)/ogr/ogr.lib $(GDAL_DIR)/ogr/../port/cpl.lib
OGR_INC = -I$(GDAL_DIR)/ogr/ogrsf_frmts -I$(GDAL_DIR)/ogr -I$(GDAL_DIR)/ogr/../port
# ESRI SDE support.
SDE_OPT=-DUSE_SDE
SDE_INC=-I C:\arcexe80\arcsde\sqlexe\include
SDE_LIB=C:\arcexe80\arcsde\sqlexe\lib\sde80.lib C:\arcexe80\arcsde\sqlexe\lib\sg80.lib C:\arcexe80\arcsde\sqlexe\lib\pe80.lib
# UofMN GIS/Image Processing Extension (very experimental)
#EGIS=-DUSE_EGIS
#ERR_OBJ=./errLog/errLog.o
#ERR_INC=-I./errLog
#ERR_LIB=-L./errLog -lerrLog
#IMGGEN_OBJ=./imgSrc/imgLib.o
#IMGGEN_INC=-I./imgSrc
#IMGGEN_LIB=-L./imgSrc -limgGEN
# VC++ does not include the REGEX library... so we must provide our one.
# The following definitions will try to build GNU regex-0.12 located in the
# regex-0.12 sub-directory.
# If it was not included in the source distribution, then you can get it from:
# ftp://ftp.gnu.org/pub/gnu/regex/regex-0.12.tar.gz
REGEX_OBJ= .\regex\regex.obj
REGEX_INC=-I ./regex
# IMPORTANT NOTE ABOUT REGEX FOR PHP_MAPSCRIPT USERS:
# If you want to compile the PHP_MAPSCRIPT module, then you have to make
# MapServer uses the same version of the REGEX library that PHP was
# compiled with:
#PHP_REGEX=..\php-3.0.14\regex
#PHP_REGEX=..\php-4.0.6\regex
#REGEX_OBJ=$(PHP_REGEX)\regcomp.obj $(PHP_REGEX)\regerror.obj \
# $(PHP_REGEX)\regexec.obj $(PHP_REGEX)\regfree.obj
#REGEX_INC=-I$(PHP_REGEX) -DPHP_NO_ALIASES
# REGEX needs some special flags... here they are for VC++ 6.0
REGEX_OPT=-DHAVE_STRING_H -DREGEX_MALLOC
# --- You shouldn't have to edit anything else. ---
# Main MapServer library.
MS_LIB = mapserver.lib
MS_OBJS = mapbits.obj maphash.obj mapshape.obj mapxbase.obj \
mapparser.obj maplexer.obj mapindex.obj maptree.obj \
mapsearch.obj mapstring.obj mapsymbol.obj mapfile.obj \
maplegend.obj maputil.obj mapscale.obj mapquery.obj \
maplabel.obj maperror.obj mapprimitive.obj mapproject.obj\
mapraster.obj cgiutil.obj mapsde.obj mapogr.obj \
mappostgis.obj maplayer.obj mapresample.obj mapwms.obj \
mapwmslayer.obj mapgml.obj\
$(EPPL_OBJ) $(REGEX_OBJ)
MS_HDRS = map.h mapfile.h
MS_EXE = mapserv.exe shp2img.exe legend.exe \
shptree.exe scalebar.exe sortshp.exe tile4ms.exe
LIBS = $(MS_LIB) $(GD_LIB) $(TIFF_LIB) $(JPEG_LIB) $(SDE_LIB)\
$(PROJ_LIB) $(ERR_LIB) $(IMGGEN_LIB) $(OGR_LIB)
INCLUDES = $(GD_INC) $(TIFF_INC) $(JPEG_INC) $(SDE_INC)\
$(PROJ_INC) $(ERR_INC) $(IMGGEN_INC) $(REGEX_INC) $(OGR_INC)
CFLAGS = $(BASE_CFLAGS) $(INCLUDES) $(REGEX_OPT) $(STRINGS) $(SDE_OPT) \
$(EPPL) $(PROJ) $(TIFF) $(JPEG) $(GD) $(OGR) $(WMS)
default: all
all: $(MAKE_GD) $(MS_LIB) $(MS_EXE)
$(MS_OBJS): $(MS_HDRS)
$(MS_LIB): $(MS_OBJS)
copy $(GDAL_DIR)\gdal.pdb .
lib /out:$(MS_LIB) $(MS_OBJS)
$(MS_EXE): $(LIBS)
gd::
cd gd-1.8.4
nmake /f makefile.nt gd.lib OPTFLAGS="$(OPTFLAGS)"
cd ..
.c.obj:
$(CC) $(CFLAGS) /c $*.c /Fo$*.obj
.cpp.obj:
$(CC) $(CFLAGS) /c $*.cpp /Fo$*.obj
.c.exe:
$(LINK) $(LDFLAGS) $*.obj $(LIBS)
.cpp.exe:
clean:
del *.obj
del $(REGEX_OBJ)
del $(MS_LIB)
del $(MS_EXE)
del *.pdb
del *.exp
del *.ilk
cd gd-1.8.4
nmake -f makefile.nt clean
cd ..
cd gdft
nmake -f makefile.vc clean
cd ..
=======gd-1.8.4amgif.tar.gz --> makefile.nt ========
#NMAKE makefile for Windows 95/98/NT developers.
#Produces a static library (libgd.lib). Thanks to Joe Gregorio.
#This is out of date.
COMPILER=cl
#If the ar command fails on your system, consult the ar manpage
#for your system.
AR=LIB
#If the install command is not in your path, provide
#an explicit path for it here, or install manually.
INSTALL=install
#If you don't have FreeType and/or Xpm installed, including the
#header files, uncomment this (default).
#CFLAGS=-Ox -GX
#If you do have FreeType and/or Xpm fully installed, uncomment a
#variation of this and comment out the line above. See also LIBS below.
#CFLAGS=-O -DHAVE_LIBXPM -DHAVE_LIBJPEG -DHAVE_LIBPNG -DHAVE_LIBTTF
CFLAGS=-O -DHAVE_JPEG -DHAVE_LIBJPEG -DHAVE_LIBPNG -DHAVE-LIB_FREETYPE -DHAVE_LIBTTF -DMSWIN32
# -DHAVE_LIBFREETYPE can be used instead of -DHAVE_TTF to use the
# newer FreeType2 libraries
#Libraries required for applications
LIBS=gd.lib ../libpng/projects/msvc/win32/libpng/dll/libpng.lib ../zlib/release/zlib.lib ../jpeg/libjpeg.lib
#LIBS=gd.lib libpng.lib zlib.lib libjpeg.lib libttf.lib
#Libraries required for gd.lib itself
GDLIBS=../libpng/projects/msvc/win32/libpng/dll/libpng.lib ../zlib/release/zlib.lib ../jpeg/libjpeg.lib ../freetype/lib/freetype200b8.lib ../tiff/libtiff/libtiff.lib
#GDLIBS=libpng.lib zlib.lib libjpeg.lib libttf.lib
#Typical install locations for freetype, zlib, jpeg, xpm and
#libpng header files. If yours are somewhere else, change this.
INCLUDEDIRS=-I../zlib -I../libpng -I../jpeg -I../freetype/lib -I../freetype/include/freetype -I../freetype/include -I../tiff
#Typical install locations for freetype, zlib, xpm, libjpeg and
#libpng libraries.
#If yours are somewhere else, other than a standard location
#such as /lib or /usr/lib, then change this. Be sure to keep
#-L. as this allows the gd library itself to be found.
#Put -L. first so that old versions of the gd library elsewhere
#on your system can't cause conflicts while building a new one.
LIBDIRS=
#Location where gd.lib should be installed by "make install".
INSTALL_LIB=C:\Program Files\Microsoft Visual Studio\VC98\Lib
#Location where .h files should be installed by "make install".
INSTALL_INCLUDE=C:\Program Files\Microsoft Visual Studio\VC98\Include
#Location where useful non-test programs should be installed by "make install".
INSTALL_BIN=C:\Program Files\Microsoft Visual Studio\VC98\Bin
# Changes should not be required below here.
VERSION=1.8.1
CC=$(COMPILER) $(INCLUDEDIRS)
LINK=$(CC) $(LIB)$(LIBS)
PROGRAMS=$(BIN_PROGRAMS) $(TEST_PROGRAMS)
BIN_PROGRAMS=pngtogd.exe pngtogd2.exe gdtopng.exe gd2topng.exe gd2copypal.exe gdparttopng.exe webpng.exe gd2togif.exe gdcmpgif.exe giftogd2.exe
TEST_PROGRAMS=gdtest.exe gddemo.exe gd2time.exe gdtestttf.exe gdtestft.exe
all: gd.lib $(PROGRAMS)
gddemo.exe: gddemo.c gd.lib
$(CC) gddemo.c $(LIBDIRS) $(LIBS)
pngtogd.exe: pngtogd.c gd.lib
$(CC) pngtogd.c $(LIBDIRS) $(LIBS)
webpng.exe: webpng.c gd.lib
$(CC) webpng.c $(LIBDIRS) $(LIBS)
pngtogd2.exe: pngtogd2.c gd.lib
$(CC) pngtogd2.c $(LIBDIRS) $(LIBS)
gdtopng.exe: gdtopng.c gd.lib
$(CC) gdtopng.c $(LIBDIRS) $(LIBS)
gd2topng.exe: gd2topng.c gd.lib
$(CC) gd2topng.c $(LIBDIRS) $(LIBS)
gd2copypal.exe: gd2copypal.c gd.lib
$(CC) gd2copypal.c $(LIBDIRS) $(LIBS)
gdparttopng.exe: gdparttopng.c gd.lib
$(CC) gdparttopng.c $(LIBDIRS) $(LIBS)
gdtest.exe: gdtest.c gd.lib
$(CC) gdtest.c $(LIBDIRS) $(LIBS)
gd2time.exe: gd2time.c gd.lib
$(CC) gd2time.c $(LIBDIRS) $(LIBS)
gdtestttf.exe: gdtestttf.c gd.lib
$(CC) gdtestttf.c $(LIBDIRS) $(LIBS)
gdtestft.exe: gdtestft.c gd.lib
$(CC) gdtestft.c $(LIBDIRS) $(LIBS)
gd2togif.exe: gd2togif.c gd.lib
$(CC) gd2togif.c $(LIBDIRS) $(LIBS)
gdcmpgif.exe: gdcmpgif.c gd.lib
$(CC) gdcmpgif.c $(LIBDIRS) $(LIBS)
giftogd2.exe: giftogd2.c gd.lib
$(CC) giftogd2.c $(LIBDIRS) $(LIBS)
OBJS=gd.obj gdhelpers.obj gd_gd.obj gd_gd2.obj gd_io.obj gd_io_dp.obj gd_io_file.obj gd_ss.obj \
gd_io_ss.obj gd_png.obj gdxpm.obj gdfontt.obj gdfonts.obj gdfontmb.obj gdfontl.obj \
gd_gif_in.obj gd_gif_out.obj gd_biggif_out.obj gd_lzw_out.obj \
gdfontg.obj gdtables.obj gdttf.obj gdft.obj gdcache.obj gdkanji.obj gd_jpeg.obj gd_wbmp.obj wbmp.obj
gd.lib: $(OBJS) gd.h gdfontt.h gdfonts.h gdfontmb.h gdfontl.h gdfontg.h
$(AR) $(OBJS) $(GDLIBS)
clean:
del *.obj *.lib $(PROGRAMS)
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20010924/5a52fc98/attachment.html
