[mapserver-users] php mapscript doesn't work whith php 4.0.4pl1
Jeff McKenna
mckenna at dmsolutions.ca
Wed Sep 26 08:54:06 EDT 2001
Sylvain Pasche wrote:
> Hello,
> I've tried to compile the latest cvs version of mapserver, with php
> mapscript.
> However, php mapscript does not work any more with php version
> 4.0.4pl1. In fact, there is an unresolved symbol "add_property_zval"
> with does not exist in php 4.0.4pl1, but is in php4.0.6.
> Does it mean that php mapscript is not compatible with php4.0.4pl1 any
> more ?
> or is it possible to use a work around to keep compatibility with
> older versions ?
> Regards
> Sylvain
Sylvain,
You are correct, phpMapscript code was recently modified to reflect
memory leak fixes in php4.0.6. I recommend that you just upgrade to
php4.0.6. The PHP/Mapscript documentation will be updated with this
information.
Jeff
Jeff McKenna
GIS Specialist
DM Solutions Group Inc.
Ottawa, Ontario
http://www.dmsolutions.ca/
