[mapserver-users] PHP, Create Layer on Fly - HELP
Hankley, Chip
Chip.Hankley at GASAI.Com
Fri Sep 28 16:33:18 EDT 2001
OK, I'm totally lost. I'm trying to embed a legend into my map. I've created
a PNG of my legend, and I want it to always render at the LL of my image.
What I'm trying to do is create a point layer on the fly, using the PNG
image as my symbol.
I'm getting a couple of PARSE errors...lines 18 and 22, that are befuddling
me.
If I just comment these out, I get the following fatal error:
Fatal error: Object has an invalid '_map_handle_' property in
c:\inetpub\wwwroot\seating\seating.php on line 42
I feel like I'm misreading the 3.5 PHP docs somehow.
Any help, as always, is much appreciated.
Chip
Here's the snippets of code:
1 $img = $map->draw();
2 embed_legend($map, $Cur_Extent, $img);
3
4 function embed_legend($map, $Cur_Extent, $img) {
5 //$map is the current MapObject
6 //$Cur_Extent is an array where:
7 //$Cur_Extent[0] = Xmin
8 //$Cur_Extent[1] = Ymin
9 //$Cur_Extent[2] = Xmax
10 //$Cur_Extent[3] = Ymax
12 //$img is the current ImageObject
13
14 //Create a new Point Layer
15 $layer = ms_newLayerObj($map);
16 $layer->set("name", "legend");
17 $layer->set("type", MS_LAYER_POINT);
18 $layer->set{"status", 1); //THIS GIVES ME A PARSE ERROR
19
20 //Create a new Class for the Layer
21 $class = ms_newClassObj($layer);
22 $class->set{"name", "legendclass"); //THIS GIVES ME A PARSE ERROR
23 $symb = $map->getSymbolByName('symbols/legend.png');
24 $class->set("symbol", $symb);
25
26 //Place the point so that it is 52 pixels IN and 41
27 // pixels UP from the lower left hand conrner of
28 // the image. We are using an image that is 100 x 80
29 // pixels... this should put the image just inside
30 // the rendered image.
31 $ImgWidth = $map->width;
32 $ImgHeight = $map->height;
33 $Pixel_X = ($Cur_Extent[2] - $Cur_Extent[0]) / $ImgWidth;
34 $Pixel_Y = ($Cur_Extent[3] - $Cur_Extent[1]) / $ImgHeight;
35 $Spot_X = $Cur_Extent[0] + 52 * $Pixel_X;
36 $Spot_Y = $Cur_Extent[1] + 41 * $Pixel_Y;
37
38 $point = ms_newpointObj();
39 $point->setXY($Spot_X, $Spot_Y);
40 $point->draw($map,$layer,$img,'legendclass',undef);
41
42 $layer->draw($img);
43 }
