[mapserver-users] Problems..
Lowell.Filak
lfilak at medinaco.org
Tue Apr 2 16:34:44 EST 2002
Hmmm... Good point.
Attached is an update to the dump.pl in the mapscript/perl/examples
directory that prints the bounding rectangle at the end of the printout.
Note: If your running it on a big shapefile and are interested in more
than just the final extent make sure to send the output to a file.
perl dump.pl -file=<shapefilename_without_ext> > shapefile.dump
On Tue, 2 Apr 2002, Paul Peterson wrote:
> It works... I was able to determine the extents and unit with ArcExplore 3.1
> I'm still very new with Shapefiles and GIS in general. I was hoping shpinfo
> or shpdump would present whatever information contained in a file in an easy
> to read/understand tabular layout.
> Thanks for the info.
> Thanks.
> -----Original Message-----
> From: Steffen_Macke at dorsch.com.jo [mailto:Steffen_Macke at dorsch.com.jo]
> Sent: Monday, April 01, 2002 10:55 PM
> To: Paul Peterson; mapserver
> Subject: RE: [mapserver-users] Problems..
> Paul,
> try to switch on the scalebar in ArcExplorer, this shoul allow you to
> determine the
> extents of the map.
> Steffen
#!/usr/bin/perl
use mapscript;
use Getopt::Long;
%types = ( '1' => 'point',
'3' => 'arc',
'5' => 'polygon',
'8' => 'multipoint'
my $shapeminx = 0,
my $shapeminy = 0;
my $shapemaxx = 1;
my $shapemaxy = 1;
&GetOptions("file=s", \$file);
if(!$file) {
print "Syntax: dump.pl -file=[filename]\n";
exit 0;
$shapefile = new shapefileObj($file, -1) or die "Unable to open shapefile $file";
print "Shapefile opened (type=". $types{$shapefile->{type}} .") with ".
$shapefile->{numshapes} ." shape(s)\n";
$shape = new shapeObj(-1);
for($i=0; $i<$shapefile->{numshapes}; $i++) {
$shapefile->get($i, $shape);
print "Shape $i has ". $shape->{numlines} ." part(s) - ";
# Get the bounds.
my $minx = $shape->{bounds}->{minx};
my $miny = $shape->{bounds}->{miny};
my $maxx = $shape->{bounds}->{maxx};
my $maxy = $shape->{bounds}->{maxy};
printf "bounds (%f,%f) (%f,%f)\n", $minx, $miny, $maxx, $maxy;
# Is this the first shape.
if ( $i == 0 ) {
# Set the initial bounds.
$shapeminx = $minx;
$shapeminy = $miny;
$shapemaxx = $maxx;
$shapemaxy = $maxy;
else {
# Create compounded shapefile extent.
if ($minx < $shapeminx) {
$shapeminx = $minx;
if ($miny < $shapeminy) {
$shapeminy = $miny;
if ($maxx > $shapemaxx) {
$shapemaxx = $maxx;
if ($maxy > $shapemaxy) {
$shapemaxy = $maxy;
for($j=0; $j<$shape->{numlines}; $j++) {
$part = $shape->get($j);
print "Part $j has ". $part->{numpoints} ." point(s)\n";
for($k=0; $k<$part->{numpoints}; $k++) {
$point = $part->get($k);
print "$k: ". $point->{x} .", ". $point->{y} ."\n";
# Print the shapefiles bounding rectangle.
print "$file\'s Bounding Rectangle is $shapeminx, $shapeminy, $shapemaxx, $shapemaxy\n";
