AW: [mapserver-users] datum transformation with php_proj.dll
Maul, Andreas-Alexander
Andreas.Maul at bgr.de
Wed Apr 3 06:05:13 EST 2002
Thanks Frank,
it is good to know how to specify all necessary parameters for the datum
shift to get the proper results. I am now able to add the Potsdam datum
parameters to the transformation.
Best regards,
Andreas
-----Ursprüngliche Nachricht-----
Von: Frank Warmerdam [mailto:warmerdam at pobox.com]
Gesendet am: Dienstag, 2. April 2002 17:18
An: Maul, Andreas-Alexander
Cc: UMN MapServer
Betreff: Re: [mapserver-users] datum transformation with php_proj.dll
Maul, Andreas-Alexander wrote:
> Hi,
> I have the following problem with php-proj.dll (from
> php4.1.2_php_mapscript_36-dev_libwww.zip) and similar with cs2cs (from
> proj-4.4.3):
> I want to perform a coordinate and datum transformation from geographic
> coordinates (WGS84 ellipsoid) to Gauss-Krueger coordinates (i.e. do a
> transversal Mercator projection with Bessel ellipsoid corresponding to
> epsg:31493) and using php.
> Applying this php code:
> <?php
> $lat = doubleval(54.);
> $lon = doubleval( 9.);
> $paramll[0] = "proj=latlong";
> $paramll[1] = "ellps=WGS84";
> $projll = pj_init($paramll);
> $paramgk[0] = "proj=tmerc";
> $paramgk[1] = "ellps=bessel";
> $paramgk[2] = "lat_0=0.";
> $paramgk[3] = "lon_0=9.";
> $paramgk[4] = "k=1.";
> $paramgk[5] = "x_0=3500000.";
> $paramgk[6] = "y_0=0.";
> $paramgk[7] = "units=m";
> $projgk = pj_init($paramgk);
Andreas,
The problem is that you haven't specified the datums and PROJ.4 doesn't
automatically convert between ellipsoids. If you want do the above
translation and assuming no datum shift is needed (likely a bad assumption)
you would just need to specify "0" datum shift parameters. Use +datum=WGS84
for WGS84, and "+ellps=bessel +towgs84=0,0,0" for the bessel indicating that
no datum shift is required to shift to wgs84.
Hopefully I will incorporate some improved warnings into PROJ.4 in the
future
as this is a frequently encountered problem.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
and watch the world go round - Rush | Geospatial Programmer for Rent
