[mapserver-users] RE: dynamically allocated points for MAP w/ PHP
E Perik
erwin at perik.nu
Wed Apr 3 16:22:33 EST 2002
Hi Scott,
There is nothing wrong with the PHP code, except it does not create a
layer, but it creates a new shapefile ;-)
So you want to create a layer, dynamicly, or .....
Example of creating a layer from a shapefile:
0) Create map-object
1) Get object/points from existing-shapefile or from database
2) Put it in new-shapefile (as you did in your php-script)
3) Create dbf-file with name of new-shapefile
4) Clear new-shapefile (as you did)
5) Add new-layer to map-object (default of this layer is set to OFF)
6) Show new-layer (turn it ON)
7) Draw the map (now includes newly created shapefile ;-) )
Explanation:
*** In 0) you use like: $Map = ms_newMapObj("blabla.map");
*** In 1) you determine input. This could be the 3 points you have in
your example, but also could be a shape or lat/lon from a database (eg.
dbf/MySQL)
*** Option 2) and 3) and 4) you have in your mapscript. This creates a
shapefile + corresponding dbf-file.
*** Option 5) and 6) is best done using a dummy-layer which is set to
OFF in your map-file. You turn it on AND attach the new shapefile-data
from by using:
$Dummylayer = ms_newLayerObj($Map); // a new layerobject
$Dummylayer = $Map->getLayerByName("MapLayer");
$Dummylayer->set("status", 1); // Turn it on
$Dummylayer->set("data", $shpFname); // Add your created
data
While your map-layer looks something like:
LAYER
NAME "MapLayer"
TYPE POINT
STATUS OFF
CLASS
SYMBOL 'circle'
COLOR 0 0 0
SIZE 3
END
END
*** Option 7) is something like:
$ImgMap = $Map->draw();
This should do the trick.
Erwin
-----Original Message-----
Sent: Wednesday, April 03, 2002 10:28 PM
To: Consult IT!, E. Perik; mapserver-users at lists.gis.umn.edu
Subject: dynamically allocated points for MAP w/ PHP
what is wrong with this PHP code? i am trying to create a layer of
points
using mapscript. i had this working previously, then somehow deleted
the
file. now i cant figure it out again:
if ($init==1) {
// recreate the site layer
$shpFname = "C:\\Program Files\\Apache\\htdocs\\mich\\data\\shptest";
$shpFile = ms_newShapeFileObj($shpFname, MS_SHP_POINT);
$def = array(array("PROG_ID", "N", 5, 0));
$dbfFile = dbase_create($shpFname . ".dbf", $def);
createPoint( 14, 34, 111);
createPoint( 33, 14, 222);
createPoint( 10, 20, 333);
// done... cleanup
$shpFile->free();
dbase_close($dbfFile);
function createPoint($x, $y, $name){
GLOBAL $shpFile, $dbfFile;
// Create shape
$oShp = ms_newShapeObj(MS_SHP_POINT);
$oLine = ms_newLineObj();
$oLine->addXY($x, $y);
$oShp->add( $oLine );
$shpFile->addShape($oShp);
// Write attribute record
dbase_add_record($dbfFile, array($name));
