[mapserver-users] getAllLayerNames() in PHP/Mapscript
Hankley, Chip
Chip.Hankley at GASAI.Com
Thu Apr 4 09:40:22 EST 2002
Do you have the NAME value filled in your map file (like below)?
LAYER
NAME "OP0"
DATA o20_scale.tif
MINSCALE 24600
STATUS DEFAULT
OFFSITE 0
TYPE RASTER
END
LAYER
NAME "OP1"
MAXSCALE 24600
MINSCALE 9218
STATUS DEFAULT
TILEINDEX "tile_test\s10images\o_10scale.shp"
TILEITEM "Location"
TYPE RASTER
OFFSITE 0
END
I ran the following code on a map file and it worked fine...
$map = ms_newMapObj("test.map");
$a = $map->getAllLayerNames();
foreach ($a as $v) {
echo "$v<BR>";
btw... I'm running 3.5 mapscript, php 4.06, win2K w/ IIS.
Chip
-----Original Message-----
From: Puneet Kishor [mailto:pkishor at GeoAnalytics.com]
Sent: Wednesday, April 03, 2002 7:27 PM
To: 'mapserver-users at lists.gis.umn.edu'
Subject: [mapserver-users] getAllLayerNames() in PHP/Mapscript
$arLayers = mapObj->getAllLayerNames()
should yield an array of all layer names, no?
I get an array with the correct number of elements in it... but the elements
have no value... they are all empty.
What am I missing?
pk/
