[mapserver-users] RE: dynamically allocated points for MAP w/ PHP
E Perik
erwin at perik.nu
Thu Apr 4 18:02:35 EST 2002
Hi Pushkar,
Just to check the obvious,....
1) Does it echo the layername?
2) Should you not use 'explode' for $layer when multiple are selected?
3) Is the layername an existing one and not too long?
4) Is the layer STATUS set to: DEFAULT or ON ?
5) Is the layer set in your url like:
http://localhost/.../name.php?zoom=1&layer="layer1 layer2 layer3"
6) You sure POST is correct? Did you check GET ?
Option 2) should use a string like "layer1 layer2 layer3" (see option 5)
and then you explode it using the space so you then use $layer[0] for
your first layer of the 'original-string-array'
For exploding use something like:
$LayerArray = explode(" ", $HTTP_GET_VARS["layer"]);
Then from the example above you get:
$LayerArray[0] would be "layer1"
$LayerArray[1] would be "layer2"
$LayerArray[2] would be "layer3"
Erwin
-----Original Message-----
[mailto:owner-mapserver-users at lists.gis.umn.edu] On Behalf Of Pushkar
Pradhan
Sent: Thursday, April 04, 2002 7:56 PM
To: mapserver-users at lists.gis.umn.edu
Subject: Re: [mapserver-users] RE: dynamically allocated points for MAP
w/ PHP
I have a related question, in php/mapscript I show the user a html list
from which he/she can select layers to add to the current view, I am
writing some code but it doesn't work can somebody provide me with the
algorithm if not the code like the one given below:
if ( isset($HTTP_POST_VARS["layer"]) ) {
echo $HTTP_POST_VARS["layer"];
$layer = $map->getLayerByName($HTTP_POST_VARS["layer"]);
$image = $map->prepareImage();
$layer->draw($image);
$image_url = $image->saveWebImage(MS_PNG,1,1,0);
} // end of if loop
The above code doesn't work it creates a blank image, moreover if one
selects multiple layers to display then only the last one selected is
chosen.
Thanks,
> Hi Scott, >
> There is nothing wrong with the PHP code, except it does not create a
> layer, but it creates a new shapefile ;-)
> So you want to create a layer, dynamicly, or .....
> Example of creating a layer from a shapefile:
> 0) Create map-object
> 1) Get object/points from existing-shapefile or from database
> 2) Put it in new-shapefile (as you did in your php-script)
> 3) Create dbf-file with name of new-shapefile
> 4) Clear new-shapefile (as you did)
> 5) Add new-layer to map-object (default of this layer is set to OFF)
> 6) Show new-layer (turn it ON)
> 7) Draw the map (now includes newly created shapefile ;-) )
> Explanation:
> *** In 0) you use like: $Map = ms_newMapObj("blabla.map");
> *** In 1) you determine input. This could be the 3 points you have in
> your example, but also could be a shape or lat/lon from a database
(eg.
> dbf/MySQL)
> *** Option 2) and 3) and 4) you have in your mapscript. This creates a
> shapefile + corresponding dbf-file.
> *** Option 5) and 6) is best done using a dummy-layer which is set to
> OFF in your map-file. You turn it on AND attach the new shapefile-data
> from by using:
> $Dummylayer = ms_newLayerObj($Map); // a new layerobject
> $Dummylayer = $Map->getLayerByName("MapLayer");
> $Dummylayer->set("status", 1); // Turn it on
> $Dummylayer->set("data", $shpFname); // Add your created
> data
> While your map-layer looks something like:
> LAYER
> NAME "MapLayer"
> TYPE POINT
> STATUS OFF
> CLASS
> SYMBOL 'circle'
> COLOR 0 0 0
> SIZE 3
> END
> END
> *** Option 7) is something like:
> $ImgMap = $Map->draw();
> This should do the trick.
> Erwin
> From: Scott D Cogan [mailto:cogansco at msu.edu]
> Sent: Wednesday, April 03, 2002 10:28 PM
> To: Consult IT!, E. Perik; mapserver-users at lists.gis.umn.edu
> Subject: dynamically allocated points for MAP w/ PHP
> what is wrong with this PHP code? i am trying to create a layer of
> points
> using mapscript. i had this working previously, then somehow deleted
> the
> file. now i cant figure it out again:
> if ($init==1) {
> // recreate the site layer
> $shpFname = "C:\\Program
Files\\Apache\\htdocs\\mich\\data\\shptest";
> $shpFile = ms_newShapeFileObj($shpFname, MS_SHP_POINT);
> $def = array(array("PROG_ID", "N", 5, 0));
> $dbfFile = dbase_create($shpFname . ".dbf", $def);
> createPoint( 14, 34, 111);
> createPoint( 33, 14, 222);
> createPoint( 10, 20, 333);
> // done... cleanup
> $shpFile->free();
> dbase_close($dbfFile);
> function createPoint($x, $y, $name){
> GLOBAL $shpFile, $dbfFile;
> // Create shape
> $oShp = ms_newShapeObj(MS_SHP_POINT);
> $oLine = ms_newLineObj();
> $oLine->addXY($x, $y);
> $oShp->add( $oLine );
> $shpFile->addShape($oShp);
> // Write attribute record
> dbase_add_record($dbfFile, array($name));
PUSHKAR S. PRADHAN
Research Assistant
MISSISSIPPI STATE UNIVERSITY,
STARKVILLE, MS 39759.
Engineering Research Center
Box 9627
Mississippi State, MS 39762-9627
