[mapserver-users] Mapserver Compilation Version runtime errors
Alexander Shostko
shostko at ureach.com
Fri Apr 5 15:12:13 EST 2002
Dear Map Server Users !
The opinion is appreciated on the following:
The binary distribution of mapserver comes in
both
gif and png versions.
I compiled the mapserver using the source code provided for
windows 2000. The only problems encountered were:
defining explicitly
#define bcmp(s1, s2, n) memcmp ((s1), (s2), (n))
#define bcopy(s, d, n) memcpy ((d), (s), (n))
#define bzero(s, n) memset ((s), 0, (n))
#define alloca( par ) malloc( (par))
and skipping some *.obj defined in the makefile , but not found
in regex distribution.
in regex compilcation
and replacing (as suggested in gd comments ) *gif functions
by *png functions (there are no *Gif equivalents in gd source
distribution).
void gdImageGif(gdImagePtr im, FILE *outFile)
gdImagePng(im, outFile);
} // eof
gdImagePtr gdImageCreateFromGif(FILE *inFile)
return gdImageCreateFromPng(inFile);
} // eof
in gd-1.8.4
Well, when I placed the compiled version into cgi-bin\ instead
of precompiled binaries. It gives the error
that it can not initialize the image.
? What version is compiled in source distribution: gif or png,
or anything else
? which flags I need to set to produce either gif or png version
(gif is defined by USE_GD_GIF in the source ... )
Thanks a lot
Alexander Shostko
