[mapserver-users] File paths for layer data
Tyler Mitchell
TMitchell at lignum.com
Fri Apr 5 16:13:17 EST 2002
Adam, I had come across similar problems but am not sure if it was only on
the windows platform or not. What is your "setup" - are you using windows,
cygwin, unix and maybe you could tell us what version you are using.
Tyler
"Ryan, Adam"
<ARyan at co.linn.or.us> To: mapserver-users at lists.gis.umn.edu
Sent by: cc:
owner-mapserver-users at lists.g Fax to:
is.umn.edu Subject: [mapserver-users] File paths for layer data
04/05/2002 11:29 AM
> Hi all,
> I'm new at this and on a steep learning curve but I think I'm in love
with
> MapServer. It's so fast and, for the most part, easy to use.
> One problem: I want to set 'data' for a layer object in my map file to a
> file on another drive, url, server, etc. I can't get mapserver to access
> any layer files that are outside my server directory. I have images on
> the htm template file that reference other drives and servers so it
> doesn't seem to be a rights or permissions problem.
> Any suggestions?
> Thanks,
> Adam Ryan
> Linn County GIS
> Oregon
