[mapserver-users] update (regex solution) RE: multiple matches in $classObj->setexp
ression
Puneet Kishor
pkishor at GeoAnalytics.com
Fri Apr 5 18:09:34 EST 2002
the following works...
$str = "/foo|bar|baz/";
I am still curious to know if a more traditional SQL-ish construct would
work? And why my attempts below are failing.
TIa,
pk/
> -----Original Message-----
> From: Puneet Kishor
> Sent: Friday, April 05, 2002 4:41 PM
> To: MapServer List (E-mail)
> Subject: multiple matches in $classObj->setexpression
> with the following in my map file...
> LAYER
> NAME "parcels_highlight"
> TYPE polygon
> DATA parcel
> STATUS off
> CLASSITEM "OWNER"
> CLASS
> OUTLINECOLOR 255 0 0
> COLOR 255 255 0
> END
> TEMPLATE "parcels.php"
> END
> The following works fine...
> $str = "foo";
> $classObj->setexpression("\"$str\"");
> $layerObj->set("status", 1);
> But I want to do the following, which, needless to say, does
> not work...
> $str = "([GIS_KEY] in (\"foo\", \"bar\", \"baz\"))";
> $classObj->setexpression("\"$str \"");
> In fact, I can't even get the following to work...
> $str = "([GIS_KEY] eq \"foo\")"; OR
> $str = "([GIS_KEY] == \"foo\")"; OR
> $str = "([GIS_KEY] eq 'foo')"; etc.
> What am I missing here? And if the "in" clause is not
> supported (doesn't seem to be per the docs), would I need to
> do the following...
> $str = "(([GIS_KEY] eq \"foo\") or ([GIS_KEY] eq \"bar\") or
> ([GIS_KEY] eq \"baz\"))";
> Tia,
> pk/
