[mapserver-users] multiple matches in $classObj->setexpression
Puneet Kishor
pkishor at GeoAnalytics.com
Sun Apr 7 23:24:47 EDT 2002
thanks to sw and sdl, I now know how to do this (will try it out
tomorrow at work). one thing though... the documentation makes a very
cursory mention of this peculiarity without really pointing it out...
Specifically, I could find only one passing references to attribs in
shape files at http://mapserver.gis.umn.edu/doc/mapfile-reference.html
> Logical expressions allow you to build fairly complex tests based on
> one or more attributes and therefore are only available with
> shapefiles. Logical expressions are delimited by parentheses
> "(expression)". Attribute names are delimited by square brackets
> "[ATTRIBUTE]". These names are case sensitive and must match the items
> in the shapefile. For example: EXPRESSION ([POPULATION] > 50000 AND
> '[LANGUAGE]' eq 'FRENCH') ... The following logical operators are
> supported : =,>,<,<=,>=,=,or,and,lt,gt,ge,le,eq. As you might expect
> this level of complexity is slower to process.
see the '[LANGUAGE]' eq 'FRENCH' bit... that escaped me completely, and
now is noticeable only because I have been educated about it.
Nonetheless, many thanks,
pk/
On Friday, April 5, 2002, at 07:07 PM, Stephen Woodbridge wrote:
> Puneet,
> You want to use a regular expression so in your mapfile you would say:
> CLASSITEM "GIS_KEY"
> CLASS
> EXPRESSION /^foo$|^bar$|^baz$/
> or in php you would say something like:
> $oLayer->set("classitem", "GIS_KEY");
> $oClass->setexpression("/^foo$|^bar$|^baz$/");
> I haven't tested this but it should be close to this syntax. Give it a
> try and let us know how it goes.
> -Steve W.
> Puneet Kishor wrote:
>> with the following in my map file...
>> LAYER
>> NAME "parcels_highlight"
>> TYPE polygon
>> DATA parcel
>> STATUS off
>> CLASSITEM "OWNER"
>> CLASS
>> OUTLINECOLOR 255 0 0
>> COLOR 255 255 0
>> END
>> TEMPLATE "parcels.php"
>> END
>> The following works fine...
>> $str = "foo";
>> $classObj->setexpression("\"$str\"");
>> $layerObj->set("status", 1);
>> But I want to do the following, which, needless to say, does not
>> work...
>> $str = "([GIS_KEY] in (\"foo\", \"bar\", \"baz\"))";
>> $classObj->setexpression("\"$str \"");
>> In fact, I can't even get the following to work...
>> $str = "([GIS_KEY] eq \"foo\")"; OR
>> $str = "([GIS_KEY] == \"foo\")"; OR
>> $str = "([GIS_KEY] eq 'foo')"; etc.
>> What am I missing here? And if the "in" clause is not supported
>> (doesn't
>> seem to be per the docs), would I need to do the following...
>> $str = "(([GIS_KEY] eq \"foo\") or ([GIS_KEY] eq \"bar\") or
>> ([GIS_KEY] eq
>> \"baz\"))";
>> Tia,
>> pk/
