[mapserver-users] quickly finding which point on map is nearest to mouse click
Vladimir Guzmán
vguzman at bigfoot.com
Mon Apr 8 16:22:19 EDT 2002
Scott:
I've resolved the same situation doing the following with php-mapscript:
1. Get the user's click
2. Get the desired layer
3. Turn it on
4. Create a point Object with the user's click
5. Make a querybypoint, single, and with a medium tolerance.
- It will find the nearest point -
6. Create a new shape with the new found point
My code looks like this:
(If you have questions on this, you can mail me)
$layer=$map->getLayerByName("transformadores");
$layer->set("status",1);
To convert pixel coordinates to map coordinates:
$factor=($frm["maxx"]-$frm["minx"])/$ancho;
$px=$frm["minx"]+($ZOOM_x*$factor);
$py=$frm["maxy"]-($ZOOM_y*$factor);
Create the point object:
$oPoint = ms_newPointObj();
$oPoint->setxy($px, $py);
Make the query over the layer
@$results=$layer->queryByPoint($oPoint,MS_SINGLE,1000);
$oRes = $layer->getResult(0);
$map->setextent($frm["minx"], $frm["miny"], $frm["maxx"], $frm["maxy"]);
If there is no points:
if($oRes=="") printf("There is no points near...");
else{
Create the shapefile
$layer->open($layer->shapepath);
$oShape = $layer->getShape($oRes->tileindex,$oRes->shapeindex);
$nuevo_id=$oShape->values["A02ID"];
$nueva_long=$oShape->values["A02LONGITU"];
$nueva_lat=$oShape->values["A02LATITUD"];
$shpFname = $CFG->tmppath . "ali_" . session_id();
$shpFile = ms_newShapeFileObj($shpFname, MS_SHP_POINT);
$dbfFile = dbase_create($shpFname.".dbf", array(array("ID", "N", 10, 0)));
include("funciones_shp.php");
$campos=dbase_numfields($dbfFile);
createPoint($nueva_long, $nueva_lat, $nuevo_id, $shpFile, $dbfFile);
$shpFile->free();
dbase_close($dbfFile);
$shpFname = $CFG->tmppath . "ubi_" . session_id();
$dbfFile = dbase_create($shpFname.".dbf", array(array("PROG_ID", "N", 5,
0)));
createPoint($px, $py, 1, $shpFile, $dbfFile);
$shpFile->free();
Hope this helps.
Vladimir Guzmán R.
www.main-task.com
Scott D Cogan wrote:
> I have a map with certain lat/lon coordinates marked as sites. I would like
> users to be able to click on the map and have information for the nearest
> site become highlighted. To do this, I have converted the mouse click
> coordinates to lat/lon coordinates which are mapped. Then I am planning on
> calculating for each site, the distance between the click and the site, and
> storing the remembering the closest one. Is there a quicker way to do this?
> Would it be beneficial to use the distanceToPoint function in mapscript?
> -scott
