[mapserver-users] Shapefile indices and Mapserv vs Mapscript
Sean Gillies
sgillies at i3.com
Wed Apr 10 14:56:10 EDT 2002
Greetings,
I'm finding a quirk between mapserv and mapscript and
am hoping that someone can enlighten me.
Using mapserver and mapscript 3.5 I am finding that
mapscript cannot access a shapefile without the
presence of a shptree index, while mapserv can
access the same shapefile without a shptree index,
even when using the same map (produced from map.save()).
Why would mapscript produce a msSearchDiskTree() error
when there is no error from mapserv? Do mapserv.exe
and mapserver.lib not use the same code to access
shapefiles?
I'm using mapserver and mapscript that I've built on
Win2k from the 3.5 source. Am setting the shapefile
layer to connection type MS_SHAPEFILE.
thanks,
Sean
Sean Gillies Applications Developer
i-cubed : information integration & imaging LLC
970-482-4400 voice
970-482-4499 fax http://www.i3.com
