[mapserver-users] Using MapServer with ERMapper's Image Web
Server (IWS)
Andrew Hallam
ahallam at digitalearth.com.au
Fri Apr 12 20:08:43 EDT 2002
Hi Tyler,
--On Friday, April 12, 2002 10:42 -0700 Tyler Mitchell
<TMitchell at lignum.com> wrote:
> Is anyone using MapServer with ERMappers IWS? I see a MapServer demo on
> their site about integrating MapServer with IWS, but I was wondering if
> anyone can tell me how I could add a layer into my map file that would
> grab an image from IWS (I assume using WMS).
I'm writing a WMS 1.0.0 and 1.1.x interface to do this at the moment. It
will provide a WMS interface to ECW data from Image Web Server and from
local file. (Windows only at this stage.)
In the meantime, there are two possible approaches:
** Client Side **
The ECW viewer plug-in, in your browser, would request an image from
MapServer and overlay it on the ECW raster data. All you need to do it
write some Javascript and tell the plug-in which colour in the MapServer
image to make transparent.
There are examples of this in the Image Web Server documentation, and you
can view some working examples at www.earthetc.com.
I wrote a Javascript WMS 1.0.0 library to do this a while ago. If anyone is
interested I'll see if I can dig it up.
** Server Side **
The usual approach is to run MapServer on Windows and compile it with ECW
support. That lets you read ECW data from a local file. If you want to use
Image Web Server (over HTTP) instead of a local ECW file you should be able
to replace the ECW file path in the map file with an ecwp URL (I haven't
actually tried this with MapServer but it works fine on my image server).
e.g. Replace "d:\ecwfiles\yourimage.ecw" with
"ecwp://someserver/ecw/yourimage.ecw"
Note: As previously discussed on this list, MapServer's handling of 24bit
colour still needs a bit of work so the quality of the output is not
optimum when reading ECW data.
Regards
Andrew Hallam
Digital Earth Pty Ltd
http://www.digitalearth.com.au
