[mapserver-users] PERL MINSCALE MAXSCALE display control
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Apr 16 11:00:20 EDT 2002
Joe this sounds like you might have one of the following problems:
1) your tileindex is not right
2) the extents on your shp file are wrong
3) your shp file units or mapfile units or projection are not all
compatible
4) you have an out of data *.qix file
Try setting up a test mapfile with mimimal data to make it easier to
diagnose the problem.
Hope this helps,
-Steve
Joe Bussell wrote:
> Is there anything about data which could override decalred MINSCALE and
> MAXSCALE? I have road data for Los Angeles County and the four
> surrounding counties. I declare the layer in my map file and set the
> scale range to cover every zoom level I am using and I observe an odd
> behavior. The default map does not show me the roads in LA, but the
> surrounding counties display correctly. When I zoom out all the data is
> painted. At any zoom level out away from that point I can observe the
> road network. If I try to zoom in the LA roads do not get painted.
> What are the right questions to ask debugging this? I have verified
> that the MAP, LAYER and CLASS definitions are correct in my map file by
> replacing the DATA value with other randomly selected data sets which do
> not demonstrate this behavior. Any insight would be helpful.
> Cordially,
> Joe Bussell
> td.mapName: td.map
> Type: Plain Text (text/plain)
