[mapserver-users] Multiple queries with PostGIS
Diego Magni
diego at torno.ing.unico.it
Wed Apr 17 04:45:44 EDT 2002
Dear List,
I'm working with MapServer 3.5.1 (downloaded with Windows32 binary),
PostgreSQL 7.1.1 and PostGIS 0.6.2.
I have problems for implementing multiple queries (CGI mode:
"FEATUREQUERY" or "ITEMNQUERY") because I can't modify the filter SQL
string via a form or a URL. After the selection of a new map file FILTER
parameter, the PostGIS connection doesn't open the database and the error
message appearing is
msPOSTGISLayerWhichShapes(): Query error. prep_DB:Error executing POSTGIS
DECLARE statement (0.6 failed - retried 0.5 and it failed too).
I've tried also to build multiple queries using the CLASSITEM and
EXPRESSION map file parameters and changing them via form. I've seen
that it's possible to do it, but in this way you can't use complex SQL
strings available in case of the filter change.
How can I make multiple query with the possibility of selecting item
and value to be searched by the user?
In other words, can I create queries using an association
item-value like it was possible with MapServer 3.3?
Thank you
Best regards
Diego Magni
