[mapserver-users] Fwd: zoom to query on shape attributeHI,
Lowell Filak
lfilak at medinaco.org
Wed Apr 17 09:02:12 EDT 2002
I'm not sure that everything on your list can be done without the use of Mapscript. However if you decide to check into Mapscript there should be quite a bit of discussion on those subjects.
Lowell F.
The following message was sent by "Steve Lime" <steve.lime at dnr.state.mn.us> on Tue, 16 Apr 2002 14:29:24 -0500.
> Received: from mail.state.mn.us
> (state.mn.us [156.99.125.109])
> by co5.dnr.state.mn.us; Tue, 16 Apr 2002 08:26:49 -0500
> Return-Path: <LEllenbecker at co.winnebago.wi.us>
> Received: from lists.gis.umn.edu by mail.state.mn.us with ESMTP for steve.lime at dnr.state.mn.us; Tue, 16 Apr 2002 08:25:19 -0500
> Received: from wcmail.co.winnebago.wi.us (co.winnebago.wi.us [205.213.24.35])
> by lists.gis.umn.edu (8.9.3+Sun/8.9.1) with ESMTP id IAA21862
> for <mapserver-info at lists.gis.umn.edu>; Tue, 16 Apr 2002 08:26:27 -0500 (CDT)
> Received: by WCMAIL with Internet Mail Service (5.5.2653.19)
> id <JBLDPK2C>; Tue, 16 Apr 2002 08:24:20 -0500
> Message-Id: <CF5C7B60732AD211801900805F31912F024F2E68 at WCMAIL>
> From: "Ellenbecker, Larry" <LEllenbecker at co.winnebago.wi.us>
> To: "'mapserver-info at lists.gis.umn.edu'" <mapserver-info at lists.gis.umn.edu>
> Subject: zoom to query on shape attributeHI,
> Date: Tue, 16 Apr 2002 08:24:20 -0500
> Return-Receipt-To: "Ellenbecker, Larry" <LEllenbecker at co.winnebago.wi.us>
> X-Mailer: Internet Mail Service (5.5.2653.19)
> MIME-Version: 1.0
> Content-Type: text/plain; charset="iso-8859-1"
> HI,
> I've been checking query/filter listings and have not found a snippit that
> does what I want. I'm using ms 3.5 in basic cgi. I need help with:
> 1. I want to use a itemtype text prompt to have a user enter a parcel
> id number from my webpage.html. Everything I find seems to be derived from a
> select list.
> 2. Select the parcel from the parcel layer .dbf attribute table. Need
> syntax for the webpage.map file.
> 3. Zoom to that parcel and outline it with a contrasting color from the
> normal parcel layer in the normal webpage map display area.
> Thanks in advance.
> Larry
> GIS System Analyst
> Winnebago County
