[mapserver-users] WINNT + PROJ question
Daniel Morissette
morissette at dmsolutions.ca
Wed Apr 17 12:05:09 EDT 2002
Debbie Pagurek wrote:
> I am getting the error:
> msProcessProjection(): Projection library error. no system list, errno: 289940991
> Anybody know what this means and how to fix it?
This can happen if you use EPSG projection codes (e.g. init=epsg:4326)
but the file "epsg" is missing in the proj directory
(/usr/local/share/proj/epsg on Unix), or if you try to use an epsg:XXXX
code that doesn't exist in that file.
You may want to upgrade to the latest version of PROJ.4 on the machine
that gives this error (the latest PROJ should include the 'epsg' file).
Or you can download a copy of the epsg file from
http://www2.dmsolutions.ca/mapserver/dl/proj4-epsg.zip
If your server runs on Windows, then the epsg file is searched in either
C:\PROJ, or C:\PROJ\NAD depending on the version of PROJ that was used
to compile MapServer.
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
