[mapserver-users] Help with compiling on Suse7.3 (FWD)
Pushkar Pradhan
pushkar at ERC.MsState.Edu
Thu Apr 18 13:00:06 EDT 2002
>From your configure messages it seems you're trying to use GIF support
also and your gd version doesn't support it or you have multiple gds on
your system and mapserver is not finding the right one, if so then you
have to point it for mapserver using the --with options.
> ------------- Begin Forwarded Message -------------
> X-Originating-IP: [217.233.76.149]
> From: "Andreas Hirner" <andreas_hirner at hotmail.com>
> To: mapserver-info at lists.gis.umn.edu
> Subject: Help with compiling on Suse7.3
> Date: Wed, 17 Apr 2002 10:24:37 +0200
> Mime-Version: 1.0
> X-OriginalArrivalTime: 17 Apr 2002 08:24:37.0404 (UTC)
> FILETIME=[4FEB35C0:01C1E5E9]
> Hello,
> I'm new to MapServer and at this point I'm still evaluating it. I am also
> not very familiar with the configure and make tools. I tried to compile
> version 3.5 with the basic configuration. Configure runs without any error
> messages, but make prompts the following error:
> gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG
> -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT
> mapbits.c -o mapbits.o
> In file included from map.h:28,
> from mapbits.c:1:
> mapsymbol.h:4: gd.h: No such file or directory
> In file included from mapbits.c:1:
> map.h:34: gd.h: No such file or directory
> make: *** [mapbits.o] Error 1
> Does anybody know what's going wrong? The output of configure is listed
> below.
> Regards
> Andreas Hirner
> Configure
> loading cache ./config.cache
> checking for gcc... (cached) gcc
> checking whether the C compiler (gcc ) works... yes
> checking whether the C compiler (gcc ) is a cross-compiler... no
> checking whether we are using GNU C... (cached) yes
> checking whether gcc accepts -g... (cached) yes
> checking for c++... (cached) c++
> checking whether the C++ compiler (c++ ) works... yes
> checking whether the C++ compiler (c++ ) is a cross-compiler... no
> checking whether we are using GNU C++... (cached) yes
> checking whether c++ accepts -g... (cached) yes
> checking for ranlib... (cached) ranlib
> checking for flex... (cached) flex
> checking for yywrap in -lfl... (cached) yes
> checking for bison... (cached) bison -y
> checking if compiler supports -R... (cached) no
> checking if compiler supports -Wl,-rpath,... (cached) yes
> checking for exp in -lm... (cached) yes
> checking how to run the C preprocessor... (cached) gcc -E
> checking for ANSI C header files... (cached) yes
> checking for strcasecmp... (cached) yes
> checking for strncasecmp... (cached) yes
> checking for strdup... (cached) yes
> checking whether we should include JPEG support...
> checking for jpeg_read_header in -ljpeg... yes
> using libjpeg from system libs.
> checking which version of GD to use...
> checking where FreeType is installed...
> checking for FT_Init_FreeType in -lfreetype... no
> checking for TT_Init_FreeType in -lttf... yes
> using libfreetype -lttf from system libs.
> checking where Zlib is installed...
> checking for zlibVersion in -lz... yes
> using libz from system libs.
> checking where PNG is installed...
> checking for png_init_io in -lpng... yes
> using libpng from system libs.
> checking for gdImageCreate in -lgd... yes
> checking for gdImageGif in -lgd... no
> checking for gdImagePng in -lgd... yes
> checking for gdImageJpeg in -lgd... yes
> checking for gdImageWBMP in -lgd... yes
> checking for gdImageStringFT in -lgd... yes
> checking for gdImageString16 in -lgd... yes
> checking for gdImageGifPtr in -lgd... no
> using GD ( -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT)
> from system libs.
> checking whether we should include PDF support...
> checking for PDF_setlinewidth in -lpdf... no
> checking for PDF_setrgbcolor in -lpdf... no
> checking for PDF_moveto in -lpdf... no
> checking for PDF_curveto in -lpdf... no
> checking for PDF_show_xy in -lpdf... (cached) no
> libpdf not found... PDF support not included.
> checking whether we should include TIFF support...
> checking for TIFFOpen in -ltiff... yes
> using libtiff from system libs.
> checking whether we should include EPPL7 support...
> including EPPL7 support.
> checking whether we should include PROJ.4 support...
> PROJ.4 support not requested.
> checking whether we should include ESRI SDE support...
> ESRI SDE support not requested.
> checking whether we should compile in MPATROL support...
> MPATROL support not requested.
> checking whether we should include OGR support...
> OGR support not requested.
> checking if GDAL support requested... no
> checking if PostGIS support requested... no
> checking if OracleSpatial support requested... no
> checking whether we should include WMS support...
> OGC WMS Compatibility not enabled (PROJ.4 is required for WMS).
> checking whether we should include WMS Client Connections support...
> OGC WMS Client Connections not enabled (PROJ.4 and libwww required).
> Compiling with -DIGNORE_MISSING_DATA.
> checking for PHP/MapScript module options...
> PHP/MapScript module not configured.
> creating ./config.status
> creating Makefile
> _________________________________________________________________
> Send and receive Hotmail on your mobile device: http://mobile.msn.com
> ------------- End Forwarded Message -------------
-Pushkar S. Pradhan
