[mapserver-users] PHP and SCALE
Pushkar Pradhan
pushkar at ERC.MsState.Edu
Thu Apr 18 13:05:16 EDT 2002
Hi Stefano,
I think $gpoMap->scale is only a read only function, and must be assigning
this values to your $scale variable which is not part of the $gpoMap
object, I think you should trying using the set method:
$gpoMap->set("scalebar", "value of scale you want");
Please check the correct syntax for scalebar.
> Hi,
> one question: why, after the assignment $scale = -1 ?
> I'd like to use $scale in order to display a map only for a particular scale
> range but its value is always -1.
> $gpoMap = ms_newMapObj("mymapfile.map");
> $poLayer = $gpoMap->getlayer(1);
> $scale = $gpoMap->scale;
> Thanks.
> Stefano B.
> Outgoing mail is certified Virus Free. (FLASHH!)
> Checked by AVG anti-virus system (http://www.grisoft.com).
> Version: 6.0.350 / Virus Database: 196 - Release Date: 17/04/02
-Pushkar S. Pradhan
