[mapserver-users] Postgis and Mapscript
Harald Wehr
hwehr at hs-harz.de
Sat Apr 20 07:15:59 EDT 2002
I got the last nightly-build working.
When I try to display roads from a Postgis-Table with java-mapscript I
get the following error:
"prep_DB:Error executing POSTGIS DECLARE statement (0.6 failed -
retried 0.5 and it failed too)"
Looking in the Logfile from the PostgresqlDB following is written twice:
"ERROR: BOX3D parser - number of points should be exactly 2"
Using the exactly the same map-File with mapserver-cgi everything is
working fine. Specified roads are drawn in the png. Can anyone give some
hints why it does not work with java-mapscript?
Thanks
Harald
