AW: [mapserver-users] Problems displaying tiffs and jpegs
Nicole Bömeke
bon at ivv-aachen.de
Mon Apr 22 04:00:17 EDT 2002
I did not change the top of the demo makefile,
that means I used the following settings with no PROJECTION defined:
NAME DEMO
STATUS ON
SIZE 600 600
EXTENT 388107.634400379 5203120.88405952 500896.339019834 5310243.30613897
UNITS METERS
SHAPEPATH "data"
IMAGECOLOR 255 255 255
WEB
HEADER demo_header.html
TEMPLATE demo.html
FOOTER demo_footer.html
MINSCALE 1000
MAXSCALE 1550000
IMAGEPATH "set in demo_init.html"
IMAGEURL "set in demo_init.html"
END
Nicole
Nicole Bömeke
IVV Aachen
Germany
-----Ursprüngliche Nachricht-----
Von: owner-mapserver-users at lists.gis.umn.edu
[mailto:owner-mapserver-users at lists.gis.umn.edu]Im Auftrag von Stephen
Woodbridge
Gesendet: Freitag, 19. April 2002 14:43
An: bon at ivv-aachen.de
Cc: mapserver-users at lists.gis.umn.edu
Betreff: Re: [mapserver-users] Problems displaying tiffs and jpegs
Nicole,
The .wld files are in some kind of projection in METERS. What does the
top of your mapfile look like? Have you specified a PROJECTION .. END?
What are your EXTENTS? What are your UNITS?
I think maybe these do not match your images. Which would account for
your images not showing up.
-Steve
Nicole Bömeke wrote:
> Just for testing, I now tried to display images in .jpg format instead of
> .tif format.
> But I got the same result - nothing shows up. I think I'm doing something
> really wrong.
> I used the jpegs created through mapserver in the /temp/ directory (output
> IMAGETYPE JPEG).
> After converting them to greyscale images with Paint Shop Pro, I had two
> jpeg images
> country.jpg and lakes.jpg. In the world files for these jpegs, I used the
> minx and the
> maxy extend from the shapefiles.
> country.wld:
> 0.6
> 0.0000000000
> 0.0000000000
> -0.6
> 388107.634400379
> 5310243.30613897
> lakes.wld:
> 0.6
> 0.0000000000
> 0.0000000000
> -0.6
> 393234.393701
> 5303964.87675
> To display the jpegs I modified the .map file from the demo like this:
> # Start of layer definitions
> LAYER
> NAME ctybdpy2
> TYPE RASTER
> STATUS DEFAULT
> END
> LAYER
> NAME lakespy2
> TYPE RASTER
> STATUS OFF
> CLASS
> COLOR 49 117 185
> END
> END
> It would be gread, if you could help me, because by now I'm really stuck.
> Thanks, Nicole.
> Nicole Bömeke
> IVV Aachen
> Germany
> -----Original message-----
> >>> Nicole Bömeke <bon at ivv-aachen.de> 04/12/02 01:48 AM >>>
> > 1.) I read about an example called landsat (that uses tiffs), but I
> > can't find a link to it anywhere.
> > Can anybody tell me where I can get it or send a zipped copy of
> > it to my mail adress?
> > 2.) Are there other examples using tiffs available? I need a tiff and
> > a corresponding word file
> > that is known to work with mapserver.
> > 3.) I have the problem that my tiff does not show up.
> > It is an 8 Bit uncompressed tiff with size 600 x 600.
> > I used a world file like this:
> > 0.6
> > 0.0000000000
> > 0.0000000000
> > -0.6
> > 400000.00
> > 5255555.00
> > To try it, I replaces the background layer of the itasca example
> > by this layer definition:
> > LAYER
> > NAME ctybdpy2
> > TYPE RASTER
> > STATUS DEFAULT
> > DATA test.tif
> > END
> > Has anybody an idear what I can do?
> > Thanks, Nicole.
> > Nicole Bömeke
> > IVV Aachen
> > Germany
