[mapserver-users] recomm. for OS X (was Re: Cannot dynamically
load php_mapscript.so)
Pushkar Pradhan
pushkar at ERC.MsState.Edu
Mon Apr 22 12:45:52 EDT 2002
Kishor,
The foll. config. should be sufficient:
./configure --prefix=/rstc/user1/erc/pushkar/php-4.0.6
--with-regex=system --enable-discard-path --enable-dbase
you may need dbase to write dbf files, I think you also better use system
reg. exs. as the inbuilt regexs of php have some problems.
> Puneet Kishor wrote:
> > I read the notes on the wiki. Even if I follow those instructions, don't
> > I have to compile PHP as a CGI as well... after all, how will I get the
> > php binary unless I compile it, no? And to compile PHP as a CGI, I need
> > the Apache src to compile it against, no? The problem is that the stock
> > OS X comes pre-installed with Apache 1.3.24 and PHP 4.1.2, no src tree.
> > So, I have to ditch all of that and restart. Which, then involves
> > compiling Perl and mod_perl, because they go out of sync.
> You do not need access to an Apache source tree in order to compile PHP
> as a CGI. A CGI is by definition a standalone executable, and for this
> reason has no depency on any web server. Try removing the --with-apxs
> and/or --with-apache directives in your PHP configure options and it
> will then build as a CGI without any dependency on an Apache source tree
> (I never rebuild Apache myself).
> > Anyway, I did all of the above, and finally got php_mapsript.so to
> > compile. Now I face additional problems... I still get the message that
> > dynamic library is not supported. Enable_dl is on, yet I can't seem to
> > get dynamic libraries going. There seems to be no configuration option
> > in PHP to enable or disable this, except via the php.ini file, which I
> > have done.
> This looks like another problem that we used to have with PHP3 because
> loading of shared libraries was not enabled by default in the PHP3
> compilation process... I never ran into that problem myself with PHP4,
> but you may want to read the following FAQ and try to make the proposed
> change to the LDFLAGS in your PHP4 makefile:
> http://mapserver.gis.umn.edu/doc/phpmapscript-install-howto.html#d41e558
> There may also be an option in the PHP4 configure to enable dl ... you
> should probably look for that first.
> Daniel Morissette morissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
> Don't put for tomorrow what you can do today, because if
> you enjoy it today you can do it again tomorrow.
-Pushkar S. Pradhan
