[mapserver-users] NQUERYMAP
Dylan Keon
keon at nacse.org
Wed Apr 24 17:28:25 EDT 2002
Did you check your server error log? Let us know what it says. I'm
interested in this, because I'm also getting a 500 Internal Server Error.
Apparently I compiled something against two different versions of libpng,
and I'm getting an error because of it. Here's my error.log entry:
libpng warning: Application was compiled with png.h from libpng-1.0.12
libpng warning: Application is running with png.c from libpng-1.2.2
gd-png: fatal libpng error: Incompatible libpng version in application and
library
Can anyone tell me which application(s) this error is referring to? I
thought it was gd, so I recompiled gd making sure to reference just the
newer version of libpng, but that didn't help. I did the same thing with
MapServer, to no avail. This error is thrown when trying to load the Itasca
demo.
Thanks.
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Sent: Wednesday, April 24, 2002 12:42 PM
Subject: [mapserver-users] NQUERYMAP
Hi !
I try to execute :
http://localhost/cgi-bin/mapserv3.6?map=/data/www/gis_ms/demo5_krem_test/par
cele.map&imgsize=489+367&mapsize=489+367&imgext=399306+43548+400256+44259&la
yers=parcele&mode=nquerymap&qlayer=parcele&saveQuery=true&imgshape=100+100+2
00+200+100+200
MS returns :
The server encountered an internal error or misconfiguration and was unable
to complete your request.
Please contact the server administrator, root at gissrv.gis and inform them of
the time the error occurred, and anything you might have done that may have
caused the error.
More information about this error may be available in the server error log.
