[mapserver-users] problem with mapscript/php
E Perik
erwin at perik.nu
Thu Apr 25 17:15:31 EDT 2002
Did you check in eg ArcExplorer or in ArcView if it shows as a line?
Erwin
-----Original Message-----
[mailto:owner-mapserver-users at lists.gis.umn.edu] On Behalf Of Michel M.
dos Santos
Sent: Thursday, April 25, 2002 7:35 PM
To: mapserver-users at lists.gis.umn.edu
Subject: Re: [mapserver-users] problem with mapscript/php
Can anyone help me ?
I'm get crazy with this !!!
[]'s
Michel M. dos Santos
Em Qua 24 Abr 2002 16:08, Michel M. dos Santos escreveu:
> Hi,
> I'm with a problem with mapscript php. I try putting a shape
line, but it
> doesn't draw. If I change the type to POINT, the points are draw, when
I
> put the type to LINE , the line aren't draw.
> Can anyone help me.
> Map file:
> ##################################### OK dash
> LAYER #dash
> CLASS
> NAME "dash"
> COLOR 0 0 255
> SIZE 5
> SYMBOL "dash-long"
> END
> NAME "dash"
> STATUS ON
> TYPE LINE <--- if I change to POINT , the points are draw.
> END #dash
> code php:
> -----------8<--------------------------------------
> $figura = ms_newShapeObj(MS_SHAPE_LINE); <-- shape type LINE
> for($i=0;$i<$N;$i++){
> $ponto_obj = ms_newLineObj(); <- object point
> $ponto_obj->add($ponto[$i]); <- get the point
> $figura->add($ponto_obj); <- put in the shape
> $layer = $map->getLayerByName("dash"); <- get the layer to put shape
> $layer->addFeature($figura); <- put shape in layer
> []'s
